Author Topic: fuse selection  (Read 19835 times)
Offline Pete49
fuse selection
« on: July 27, 2013, 01:02:49 AM »
Dear collective Just after some advice on fuse selection. I have just finished repairing a Waeco power supply, a Mobitronic MPS 50 which switches 240AC to 24V DC to run a portable  fridge/freezer. The fuse in question is a 15A 250V glass fuse and I need to know if it is a fast or slow blow fuse. Its in line with the 240V input prior to the rest of the circuit. Any help would go a long way to getting this job out of my shed and back to earning its keep
Offline rdhem2
  • I LOVE SWARF!!!
Re: fuse selection
« Reply #1 on: July 27, 2013, 01:15:25 AM »
There should be some additional information in the feral on the fuse.  Like AGC, or MDL.  This is what identifies the type of fuse as far as trip characteristics.  Then voltage and amperage.  As an example  AGC 15    250vac
HTH
Russ
Offline tekfab
Re: fuse selection
« Reply #2 on: July 27, 2013, 02:45:56 AM »
I find that a 0.8mm mig tips to be excellent slow burn fuse's , never had one blow yet !  ;-)
Mike
Re: fuse selection
« Reply #3 on: July 27, 2013, 12:48:23 PM »
IMHO it needs to be a slow blo due to the inductive nature of the transformer....
Usual disclaimer...
 ...and I stand to be corrected if I'm wrong :zap:
Offline David Jupp
  • Teesside - UK
Re: fuse selection
« Reply #4 on: July 27, 2013, 01:23:08 PM »
I'd be very surprised if it is really 15A !  could it be 1.5A with a less than obvious decimal point?
Re: fuse selection
« Reply #5 on: July 27, 2013, 04:43:16 PM »
I concur with Davld,
15amp rating on he primary doesn't seem right.......
If the secondary is rated for 12 amps or so that equates to around 1.5 amps on the primary......
Offline Pete49
Re: fuse selection
« Reply #6 on: July 27, 2013, 11:33:03 PM »
there ya go I knew I could rely on you all. After the comments from David & John I went and had another look with a magnifier and yep its a 1.5 so now all fixed :clap: I had those available so now the project is moving forward again. Thank you all for the help  :mmr:
Re: fuse selection
« Reply #7 on: July 29, 2013, 12:24:52 PM »
Mike
Probably to be taken tongue in cheek, but I'm always surprised by the number of people who ignore the importance of fuses and breakers.  If it blows, there's a reason!
Re: fuse selection
« Reply #8 on: July 29, 2013, 01:15:53 PM »
There is a fairly well documented report of some plonker on the web who replaced a fuse under his dash with a .22 bullet. Apparently was some time later it went through his foot  :bugeye:
Offline mklotz
  • LA, CA, USA
Re: fuse selection
« Reply #9 on: July 29, 2013, 05:09:30 PM »
BS
http://www.snopes.com/autos/techno/fuse.asp
Regards, Marv
Home Shop Freeware
