Author Topic: Simpler lathe taper attachment?  (Read 14718 times)
Offline NeoTech
    • Roughedge Hobbyworks
Re: Simpler lathe taper attachment?
« Reply #1 on: July 11, 2013, 02:03:56 PM »
Good idea for short pieces, I like it.
Wheres the vibration from.
Offline NeoTech
« Reply #2 on: July 11, 2013, 02:08:41 PM »
Im guessing the bronze bushing is binding onto the not so smooth roundbar.. i would prolly suggest a chromed bar or something alot alot smoother.. or why not a bearing? There is cylindrical bearings that size..
Offline tekfab
« Reply #3 on: July 11, 2013, 02:13:49 PM »
Linear bearings are available in a variety of sizes. I had a similar idea and now that iv'e seen this at least i know it'll work.
Mike
Offline ieezitin
« Reply #4 on: July 12, 2013, 12:28:19 PM »
Nice.  in fact its so bloody simple it's delightfully elegant   :Doh:  You have me thinking now.............
instead of the bronze bushing you could use a ball bushing on a hardened & ground shafting and the connector on the headstock end could be a spherical Rod_end type bearing without the rod.
Well done sir..
Anthony.
