Author Topic: My shop is underway...  (Read 27785 times)
Offline ConductorX
    • The Volkswright Shop
« on: July 09, 2013, 03:09:11 PM »
Finally started my shop.  It is one of those enclosed "carports" 20 x 20.  It went up in about 6 hours and took me longer to paint the floor after.
http://i82.photobucket.com/albums/j273/ConductorX/Home%20and%20Yard/W_Lee_Hughes/DSC_0227_zps35fa0790.jpgMy shop is underway...
http://i82.photobucket.com/albums/j273/ConductorX/Home%20and%20Yard/W_Lee_Hughes/DSC_0228_zps26238bdf.jpgMy shop is underway...
http://i82.photobucket.com/albums/j273/ConductorX/Home%20and%20Yard/W_Lee_Hughes/DSC_0229_zps2c251ded.jpgMy shop is underway...
http://i82.photobucket.com/albums/j273/ConductorX/Home%20and%20Yard/W_Lee_Hughes/DSC_0231_zpse7825c49.jpgMy shop is underway...
http://i82.photobucket.com/albums/j273/ConductorX/Home%20and%20Yard/W_Lee_Hughes/shop_floor_zps786b4b8c.jpgMy shop is underway...
"G"
Offline Swarfing
Re: My shop is underway...
« Reply #1 on: July 09, 2013, 04:53:54 PM »
Wow! space for a mezzanine as well in there with that height?
Once in hole stop digging.
Offline Deko
« Reply #2 on: July 09, 2013, 05:23:01 PM »
Good thing you live somewhere warm, it would cost a small fortune to warm all that space up in a UK winter. :bugeye:  Great looking workshop though.
Cheers Dek. :med:
« Reply #3 on: July 09, 2013, 05:26:30 PM »
ooo nice
« Reply #4 on: July 09, 2013, 09:57:02 PM »
Nice space!
Offline ConductorX
« Reply #5 on: July 10, 2013, 07:52:07 AM »
Thanks for the good words everyone.  It will be easy to heat except for the high ceiling.   Last winter we actually had frost about 6 times.  The last time it snowed was 2008.
The eave height is 12 feet, I want to put in a two or four post lift for my car projects.
I also plan to air condition the shop since our problem here is heat and humidity.
Thanks again, "G"
« Reply #6 on: July 10, 2013, 09:15:59 AM »
All that space - WOW!   :bow:   :bow:   :bow:
And SIX HOURS!   :clap:   :clap:   :clap:   :clap:   :clap:   :clap:
I feel duly humbled.
« Reply #7 on: July 10, 2013, 11:30:49 AM »
Looks like it will be a great shop!
Boy, I envy you the flat open ground, probably easy sandy soil, and low heat requirements -- though I imagine air conditioning will cost similar to heat unless it will be insulated.  And, of course the speed of construction and slab floor are wonderful. Frost heaves here make slabs complicated.  :(
Excellent shop!  :thumbup: :clap:
Offline ConductorX
« Reply #8 on: July 10, 2013, 02:28:31 PM »
We pay for it in the summer time.  Working on an open concrete slab is like working on a hot griddle, just add some butter.  I am planning spray in foam insulation so it should be easy to air condition.   While I was painting the floor the temp was close 100F outside but inside with a fan running it was pretty comfy.  My big concern is machine tools rusting overnight in the humidity.
For welding and dismantling cars I plan to have an open carport with slab under half and clay on the other half.  The open sides will provide plenty of fresh air and the carport roof will provide much needed shade.
Our soil is heavy clay, hard to dig but very supportive of concrete slabs.
"G"
« Reply #9 on: July 10, 2013, 02:57:36 PM »
Why leave clay under half the car port? I would have though a concrete slab would be far more convenient - sweepable, 'jack against able' etc
Offline ConductorX
« Reply #10 on: July 11, 2013, 08:38:22 AM »
I also plan a blacksmith furnace and I want to melt and pour metal.  I have read that if I spill molten metal onto concrete it will explode from the sudden heat and changing water in the slab to steam.  I'll have 30' x 30' with concrete for jacking up cars and such.  The clay area of equal size for melting metal and doing torch work when dismantling cars.  Hard packed clay won't be that much different than the concrete.  I may have to add more in from time to time.
"G"
« Reply #11 on: July 11, 2013, 08:47:55 AM »
You know, G, I thought the same thing about concrete and pouring metal, but I've seen mixed reports and opinions about that lately, and from people I respect who have poured for a long time.
I think that for me, if and when I can build a melting shed, I will go with concrete floors, but just spread some sand on top of it around where spills are most likely -- by the furnace and the pouring area for the flasks. It can be swept up when not needed. Seems like you'd have the advantages of both.
Clay might be as much of a problem if it gets wet -- as it will if you get both rain and wind. So I'd still use sand over it in a pouring area. But lucky you for the clay -- maybe it is refractory enough to be useful in casting operations!
Offline ConductorX
« Reply #12 on: July 16, 2013, 07:42:01 AM »
That sounds like a good idea.   I just made a deal with my neighbor,   He is going to remove the big pine trees for me to help clear a space for the additional work area.
"G"
« Reply #13 on: July 16, 2013, 09:00:16 AM »
One more thought -- hope you don't mind -- a clay basin will drain into itself, even with sand in it, and hold water. A slab has the advantage that it can be above grade and always drain outwards.
Offline tekfab
« Reply #14 on: July 16, 2013, 09:35:57 AM »
It's not big enough, 6 months down the line you'll have run out of space !     :Doh:
Mike
« Reply #15 on: July 16, 2013, 09:38:17 AM »
That's true of any workshop!
