Author Topic: Presto-Lite torch rebuild  (Read 14497 times)
Offline Chuck in E. TN
  • USAF Retired
« on: June 08, 2013, 11:01:35 AM »
 I am in the process of rebuilding my Prest-O-Lite Acetylene (originally Union Carbide) torch. It’s 60 or so years old, inherited from my Dad. The o-rings in the valves have all hardened and the 401 handle leaks gas around the valve stem. I have ordered the proper o-rings from WeldingSupply.com as per the original instructions/parts list from Prest-O-Lite. I tried o-rings from a kit from HF with no joy.
My question, should I use some type of lube on the new o-rings when I install them?
Chuck
Chuck in E. TN
Re: Presto-Lite torch rebuild
« Reply #1 on: June 08, 2013, 11:18:32 AM »
No! -- unless you use one of the special lubricants formulated for use with oxygen.  30+ years ago I knew all the oxygen compatible lubes off the top of my head because I was working on that side of the universe, but I can assure you that general lubes and oxygen are a recipe for disaster...
  • USAF Retired
« Reply #2 on: June 08, 2013, 11:36:50 AM »
This is an acetelyne/Air torch, no Oxy. Still apply?
Chuck
Chuck in E. TN
« Reply #3 on: June 09, 2013, 11:13:25 AM »
Yes, to a lessor degree.  I believe you can get away with a silicon lube for most air usages.  Adding fuel (carbon) to oxygen inside the flash-over valve is just asking for an unplanned pyrotechnic event...  (We learned that the hard way with B17's during WWII.)
Offline PTsideshow
« Reply #4 on: June 29, 2013, 05:56:15 AM »
Standard answer is NO! none are needed. By the way when Prest o lite let their patent laspe, and everybody knocked off their torch almost all brands of the Prest o lite torch are interchangeable. I think there are around 6 different brand labeled ones currently.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
  • USAF Retired
« Reply #5 on: June 29, 2013, 07:42:50 AM »
I have ordered the proper replacement o-rings for the Prest-O-Lite. Still waiting for delivery 2 weeks later. In the mean time, I picked up one of the knock-offs, an Acet-O-Lite torch kit by Goss, at a flea market, complete, and in it's origional packaging, for $10US. If the new o-rings don't fix Dad's Prest-O-Lite, I'll use the other.
Chuck
Chuck in E. TN
