Author Topic: Hard Core  (Read 18633 times)
Hard Core
« on: May 06, 2013, 07:58:15 PM »
Lads
More casting video
Re: Hard Core
« Reply #1 on: May 06, 2013, 10:16:15 PM »
So, John was the core still too hard with the change in sand? Or did it turn out okay?
Re: Hard Core
« Reply #2 on: May 07, 2013, 03:52:54 AM »
For softer cores John, add less Sodium Silicate. 4% by weight at the top end working down as low as 1% for really friable ones.  For easier breakdown post casting add icing sugar to the core mix.
Years ago when I started using Sodium Silicate I made a series of test cores. I made a 8% mix, made a core, mixed in more sand to reduce the % sodium Silicate, made another core etc each time using digital kitchen scales to accurately assess the %.
The ideal does vary with the sand grain size and make up of the sodium silicate (which oddly isn't a specific composition but a ratio)
Re: Hard Core
« Reply #3 on: May 07, 2013, 08:07:04 AM »
Awemawson, what was the composition of your sodium silicate then, when you did your tests to arrive at that usable percentage range?
Re: Hard Core
« Reply #4 on: May 07, 2013, 08:32:39 AM »
The drum is in my remote 'awaiting ROUND TUITS' storage shed - I'll make a note of the composition when I'm next in there.
Offline Fredbare
  • Fakenham, Norfolk
Re: Hard Core
« Reply #5 on: May 07, 2013, 05:56:49 PM »
Another fine video, with out-takes, thanks.
Offline S. Heslop
Re: Hard Core
« Reply #6 on: May 09, 2013, 03:18:34 PM »
Nice video. I've got a couple more to watch too since I just had my internet connection fixed at last.
I'm excited about trying my hand at casting at some point but i'd better get somewhere with the armour stuff first.
Re: Hard Core
« Reply #7 on: May 09, 2013, 05:11:31 PM »
well dun john  :thumbup:
Re: Hard Core
« Reply #8 on: May 10, 2013, 05:23:10 AM »
Well the good news is I found the drum of sodium silicate  :)  The bad news is it seems to have failed to be put away in the shipping container I use - it has been sat outside for the last 5 years - the label is faded to a plain white unreadable sheet, and when I went to pick the plastic drum up by its handle, the top of the drum broke away having gone brittle with uv - so my next job is to decant it into another drum then probably throw it away :(
Re: Hard Core
« Reply #9 on: May 10, 2013, 07:24:49 AM »
Sorry to hear that awemawson -- thanks for trying anyway.  :beer:
Re: Hard Core
« Reply #10 on: May 10, 2013, 08:29:34 AM »
Now decanted into a 20 litre "Ariel Liquid" liquid soap drum - it actually looks OK and I don't suppose this stuff goes 'off' unless exposed to a dose of CO2 in concentration so I'll keep it and try a few experiments.
Just after the war I remember my parents preserving eggs on those rare occasions when they were available (we were still on food ration books then) by dipping them one by one into an Isinglass solution - which is sodium silicate. It gave them a glazed look - I suppose it sealed the pores to keep them fresh.
Re: Hard Core
« Reply #11 on: May 10, 2013, 09:23:21 AM »
Glad to hear you may be able to re-use it!  :thumbup:
Preserving eggs with water glass (isinglass is different -- it's a precipitation agent for brewing derived from fish bladders) was also practiced on cruising sailboats for long voyages without refrigeration back in the day.
Re: Hard Core
« Reply #12 on: May 10, 2013, 12:44:21 PM »
Yep you're entirely correct - it was 'Waterglass'
