MadModder
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to MadModder!
Home
Help
Search
Login
Register
MadModder
Gallery, Projects and General
Project Logs
belt sander re fit
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: belt sander re fit (Read 16861 times)
krv3000
Hero Member
belt sander re fit
on:
May 03, 2013, 06:18:33 PM »
hi all i went and pad robwilson a visit and i got a gift a belt sander thank you so much rob but as you all no by gnaw wont's its in my hands it soon ends in bits in all the sander is OK but their was things that i did not like so i started to put sum of the things right the first thing was the grad that covered the belt drive was off center and the bottom pulley was caching the cover esey fix well it ended up a lot more my intention was to cut out a hole in the bottom cover and put a cap over the hole well i needed something bigger by the time i got it figured out i needed a bigger cover (DO NOT DO THIS UNLESS YOU NO WAT YOU IS DOWNING )the cover is a bottom of a spray can the can was already empty so all that needed to be dun was to vent the can (DO THIS BIT OUT SIDE AND WELL VENTILATED) get something sharp to Peirce the can at don't mater where you put the hole as long as you is wearing goggles once the can was empty i cut the bottom off with me dremel so the gnaw dome cover was soldered on and the cover given a cote of primer pics
Logged
krv3000
Hero Member
Re: belt sander re fit
Reply #1 on:
May 03, 2013, 06:26:04 PM »
then i notist the big problem it had bin fited with a new motor wich was all to pot i had to move the motor mawnting plate and i welded in 4 bolts for the motor to fit on to i gave the motor a repant and repanted the hole thing i then fited new manse leed and put it all back together it runs sweet as a nut right pics
Logged
micktoon
Hero Member
Reply #2 on:
May 03, 2013, 06:56:42 PM »
Looking good Bob , do you have the side disc for it ? , I might have something lying around that would do the job if not
Cheers Mick
Logged
krv3000
Hero Member
Reply #3 on:
May 06, 2013, 10:55:17 AM »
hi mick i have the disc sanding part for it mick but i wood love a nuther tabel as the one that i got with it is geting used on the belt as that is in the up posishon
Logged
Guest
Reply #4 on:
May 06, 2013, 01:43:51 PM »
Looking good Bob ,,,,,,,,,New your just the bloke to sort that machine out
have you ran out of blue paint ?
Logged
NormanV
Hero Member
United Kingdom
Reply #5 on:
May 06, 2013, 02:37:35 PM »
Looking good.
I bought a new belt and disc sander similar to yours and found a design fault. The switch was next to the disc sander and after painfully sanding my finger tips (and drawing blood) a couple of times, when reaching for the switch, I removed the sanding pad and can only now use it as a belt sander which rather defeats the object of having both a disc and a belt.
Norman
Logged
awemawson
Global Moderator
Hero Member
East Sussex, UK
Reply #6 on:
May 06, 2013, 03:11:49 PM »
Move the switch !!!!!!!!!!!!!!!!!!
Logged
krv3000
Hero Member
Reply #7 on:
May 06, 2013, 03:21:38 PM »
the swich on mine is at the frunt no wher near the sanding bits no rob i still have a tin full
Logged
NormanV
Hero Member
United Kingdom
Reply #8 on:
May 06, 2013, 03:50:31 PM »
I shouldn't have to on a new machine
Logged
micktoon
Hero Member
Reply #9 on:
May 06, 2013, 03:51:29 PM »
Hi Bob , sorry no table mate , the disc is a Picador disc , I think in the days where people bought various bits and made their own machines out of them, I will keep my eyes out for table on my travels.
Cheers Mick.
Logged
Fredbare
Full Member
Fakenham, Norfolk
Reply #10 on:
May 06, 2013, 03:54:00 PM »
Great job again Bob, and fine pics.
Logged
Meldonmech
Hero Member
Reply #11 on:
May 08, 2013, 02:26:18 AM »
Hi Bob
Nice job on the mods and restoration, going to save a lot of filing.
Logged
Print
Pages: [
1
Go Up
« previous
next »
MadModder
Project Logs
belt sander re fit
