Author Topic: A lay shaft reducer for the 7x14 lathe.  (Read 24238 times)
Offline modeldozer
  • Valencia, Spain
    • AJ´s Truckmodeling
« on: April 28, 2013, 10:56:04 AM »
Hi everyone,
When I was turning the ER25 chuck and the hand wheel from large diameter steel I realized I would need to add more reduction to the lathe drive train to get better torque.
The design and build is being done as I am proceeding and adapted to materials on hand.
Started with a piece of 40mm square HRS and some round bar.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1967.jpgA lay shaft reducer for the 7x14 lathe.
The square bar was squared up and cut to size on the mill.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1969.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1970.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1971.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1972.jpgA lay shaft reducer for the 7x14 lathe.
Setup square on end and finished with a fly cutter
. http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1973.jpgA lay shaft reducer for the 7x14 lathe.
The shaft hole was marked out, located and drilled through.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1974.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1975.jpgA lay shaft reducer for the 7x14 lathe.
A bearing seat was bored.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1976.jpgA lay shaft reducer for the 7x14 lathe.
Then it was flipped over and the other bearing seat bored.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1977.jpgA lay shaft reducer for the 7x14 lathe.
Mounting holes was drilled and tapped to coincide with the original motor in the lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1981.jpgA lay shaft reducer for the 7x14 lathe.
Next, keyways was machined in the ends of a piece of 8mm round bar to form the shaft.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1979.jpgA lay shaft reducer for the 7x14 lathe.
The shaft support finished.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1980.jpgA lay shaft reducer for the 7x14 lathe.
Another chunk of square bar was sawn and machined to form a spacer for the support.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1982.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1983.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1984.jpgA lay shaft reducer for the 7x14 lathe.
For the new motor mounting a piece of 25mm calibrated square bar was setup and edges located on the mill.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1986.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1987.jpgA lay shaft reducer for the 7x14 lathe.
And the motor radius was machined on one side using the boring head.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1989.jpgA lay shaft reducer for the 7x14 lathe.
Forgot to take photos of the rest of the bracket's procedure.
Drilling and spot facing holes in a piece of 12mm shaft.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1990.jpgA lay shaft reducer for the 7x14 lathe.
And together they form the motor mounting.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1991.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1993.jpgA lay shaft reducer for the 7x14 lathe.
Drilling and reaming some holes in the fixing clamps.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1994.jpgA lay shaft reducer for the 7x14 lathe.
All mounted on the lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1995.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1996.jpgA lay shaft reducer for the 7x14 lathe.
As part of the reassembly process, the hole in the aluminium cover for the belt drive was bored bigger so it can fit over the tachometer disc on the spindle.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1997.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN1998.jpgA lay shaft reducer for the 7x14 lathe.
Now waiting for belt and pulleys to arrive.  There will be three different pulleys on the lay shaft and the motor can slide in the clamps to align with any of them.  Will start wit 2:1, 1.5:1 and direct ratios and see how it works.
Next, as part of this mod I will also add extra support to the rear of the headstock.
Cheers for now.
Abraham
Re: A lay shaft reducer for the 7x14 lathe.
« Reply #1 on: April 28, 2013, 11:17:05 AM »
Hi Abraham
Nice going  :thumbup:  , all this  modding too the lathe will make it  a cracker when your done  :dremel:  , I see your making good use of a gudgeon pin as a cylindrical square  :med:
I noticed a few shots on this and other posts of  a boring head , did you make it ?
Cheers Rob
Offline modeldozer
  • Valencia, Spain
« Reply #2 on: April 28, 2013, 11:41:23 AM »
Hi Rob.
Thanks, heres hoping all the mods make for a usable lathe.
Gudgeon pins are thanks to my previous ocupation.
The boring head was done by me, see http://madmodder.net/index.php/topic,8375.0.html
Abraham
Offline loply
« Reply #3 on: April 28, 2013, 11:55:57 AM »
Abe,
That's a nice piece of work and will no doubt work a treat.
I do wonder though, why not just fit a larger pulley onto the spindle? If you cut away a little bit from the aluminum cover you can put a very large pulley in place of the original, thus saving the need any lay shaft.
I did this on my old 7x14 and got the top speed down from 1,110rpm to around 650rpm, so almost halved it (or doubled the torque).
Cheers,
Rich
Offline modeldozer
  • Valencia, Spain
« Reply #4 on: April 28, 2013, 03:06:22 PM »
Hi Rich,
the resons for the layshaft route are,
can have more than one ratio .
and it gives me room to ad much needed support to the rear of the headstock.
More to follow.
Abraham
« Reply #5 on: April 28, 2013, 04:03:54 PM »
Cracking job I think... :thumbup: despite the comments...
You go ahead and do your own thing Abe...great entertainment.  :clap:
« Reply #6 on: April 28, 2013, 05:48:46 PM »
Great looking mods
Very well shown
I have a couple of big gudion pins as well
« Reply #7 on: April 28, 2013, 05:52:25 PM »
well dun good job
Offline modeldozer
  • Valencia, Spain
« Reply #8 on: April 29, 2013, 06:16:34 PM »
Hi John, john and krv3000,
Thanks for the encorragement.
Abraham
Offline modeldozer
  • Valencia, Spain
« Reply #9 on: April 30, 2013, 05:53:45 PM »
Hi all,
While I am waiting for the belt and pulleys to arrive I made the rear headstock support
Machined a piece of 10mm plate square and did a cutout in one side.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2001.jpgA lay shaft reducer for the 7x14 lathe.
Made a half moon cutout at the top to go around the gear change lever.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2002.jpgA lay shaft reducer for the 7x14 lathe.
The two pieces that will make up the support.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2003.jpgA lay shaft reducer for the 7x14 lathe.
Drilling the holes to bolt the two together.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2004.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2005.jpgA lay shaft reducer for the 7x14 lathe.
Set up the smaller piece and cut a chamfer at the outer top.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2006.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2008.jpgA lay shaft reducer for the 7x14 lathe.
Drilled the holes to bolt it to the headstock, and a large hole for the cables to pass through.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2009.jpgA lay shaft reducer for the 7x14 lathe.
And fitted to the lathe.  At the bottom it bolts to the heavy channel the lathe bed is bolted to.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2010.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2011.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2012.jpgA lay shaft reducer for the 7x14 lathe.
Abraham,
Offline modeldozer
  • Valencia, Spain
« Reply #10 on: May 08, 2013, 06:27:58 PM »
Good evening al modders,
The pulleys and bits finally arrived.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2014.jpgA lay shaft reducer for the 7x14 lathe.
So I started a small production line to drill, ream and cut keyways in all the pulleys.
I used pulleys and a belt from my CNC router so I could use the lathe.  At 2:1 ratio it had a lot of torque, enough to ream the holes at 50 RPM without any difficulty.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2015.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2016.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2018.jpgA lay shaft reducer for the 7x14 lathe.
Then it was over to the mill to drill and tap some holes for grub screws.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2019.jpgA lay shaft reducer for the 7x14 lathe.
Then disaster struck when I broke the second tap in the large pulley.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2021.jpgA lay shaft reducer for the 7x14 lathe.
The middle size pulley had its hub removed.  I could do facing cuts of 1mm at a time with no problem, something that was impossible in the past.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2022.jpgA lay shaft reducer for the 7x14 lathe.
When I got around to remove the hub of one of the small pulleys, the lathe was striped down again, and not wanting to reassemble it, I cut it down in the mill with a fly cutter.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2025.jpgA lay shaft reducer for the 7x14 lathe.
All done.  The 2:1 ratio is a bit slow for normal use so it was set on the 1.5:1 for now.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2026.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2027.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2029.jpgA lay shaft reducer for the 7x14 lathe.
I have not used it much yet, but between the additional head support and increased torque there is a definite improvement.
Next up is a new guard for the motor.
Abraham
Offline modeldozer
  • Valencia, Spain
« Reply #11 on: May 09, 2013, 05:56:00 PM »
Hi all,
I think I have come up with a design for the motor guard.  Had a few pieces of sheet cut by a friend.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2030.jpgA lay shaft reducer for the 7x14 lathe.
After doing some cutouts the pieces was soldered together with plumbers tin solder.  Unfortunately my gas torch does not work well for doing this with silver solder.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2031.jpgA lay shaft reducer for the 7x14 lathe.
Loosely fitted on the lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2032.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2033.jpgA lay shaft reducer for the 7x14 lathe.
Then made a hinge for it so it can be opened and closed easily.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2034.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2036.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2038.jpgA lay shaft reducer for the 7x14 lathe.
Added a border at the top edge to prevent chips from entering.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2037.jpgA lay shaft reducer for the 7x14 lathe.
And working on the lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2039.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2040.jpgA lay shaft reducer for the 7x14 lathe.
Still need to add some reinforcement and bits, more to follow.
Abraham
« Reply #12 on: May 09, 2013, 07:34:02 PM »
Hi Abraham,
You might consider heat build-up inside the motor enclosure, and put some ventilation in there. David (Stilldrillin) has burned out a motor or two, so he fitted a computer fan. So did I. David's is in this thread:
 http://madmodder.net/index.php/topic,7560.0.html
and mine is shown here:
 http://andysmachines.weebly.com/motor-cooling-fan.html
Offline modeldozer
  • Valencia, Spain
« Reply #13 on: May 10, 2013, 10:05:47 AM »
Hi Andy.
Thank you for mentioning a fan, I will keep it in mind, especialy since I also cooked a motor.  Nothing burned, just lost all its power.
Abraham
Offline modeldozer
  • Valencia, Spain
« Reply #14 on: May 19, 2013, 06:13:04 AM »
Hi everyone,
Finally had some clear whether to finish the guard.
Punched a hole for the power cable.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2042.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2043.jpgA lay shaft reducer for the 7x14 lathe.
Build a fixing system for when it is closed.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2046.jpgA lay shaft reducer for the 7x14 lathe.
And all done, painted and fitted.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2051.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2052.jpgA lay shaft reducer for the 7x14 lathe.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/LayshaftReducer/DSCN2053.jpgA lay shaft reducer for the 7x14 lathe.
Abraham
« Reply #15 on: May 19, 2013, 06:19:23 AM »
Very neat and well finished Abraham , Well done   :clap: :clap: :thumbup:
« Reply #16 on: May 19, 2013, 08:07:31 AM »
Well done Abraham!  :clap: :clap:
Looking really professional.
Don't forget Andy's tip, re. cooling fan. It makes a BIG difference........ :thumbup:
« Reply #17 on: May 19, 2013, 09:21:01 AM »
Very neat, Abraham. You are a lot better than me at folding up sheet metal.
Did you make your own toolpost? That thick central pillar looks as solid as a rock.
PS Don't forget the cooling fa...Oh, never mind!
Offline modeldozer
  • Valencia, Spain
« Reply #18 on: May 19, 2013, 11:23:44 AM »
Rob, David,
Thanks for the comments.
Andy,
The sheet metal was not folded, I cut all the panels and soldered them together.
The toolpost is self made, it is part of the QCTP amongst the Ralph Patterson plans on the tools and mods site.
Have not forgotten the fan, it will be part of the the phase of mods.
Abraham
« Reply #19 on: May 19, 2013, 01:35:42 PM »
Abraham
Even though I haven't been saying anything I have been following along with your mods. I think your doing a first rate job and it will pay you back every time that you use the lathe. Your next mod of some air flow around the motor will also help to extend the life of the motor.
Thanks for taking the time to do the photo's and explanations for us. I know it is time consuming on your part and the members do appreciate it.  :D :D
