Author Topic: Simple QRTP  (Read 24932 times)
Offline Bill Stupak
Simple QRTP
« on: April 19, 2013, 06:09:19 PM »
This is a simple QRTP design I'm trying out. I made it to work with existing tool holders that came with an A to Z tool post. It works by expanding the male dovetail on the post with a cap screw that bears against one side of the dovetail. The slot running along the side allows that side of the dovetail to flex enough  (.010")  to firmly bind the tool holder. It was pretty easy to make and seems to work pretty well.
Bill S
Re: Simple QRTP
« Reply #1 on: April 19, 2013, 10:29:18 PM »
That's pretty cool.
Question would it have better bearing on the base on your lathe if it was made from square stock instead of round?
Offline Bill Stupak
Re: Simple QRTP
« Reply #2 on: April 20, 2013, 07:23:46 AM »
Probably, but it was the material I had on hand, also it is still larger than the A to Z tool post.
Re: Simple QRTP
« Reply #3 on: April 20, 2013, 08:30:21 AM »
Oh, well, then that was the best material for the job!  :beer:
Offline Sid_Vicious
Re: Simple QRTP
« Reply #4 on: April 20, 2013, 01:31:24 PM »
Nice, Me like!
Offline drmico60
    • mikesworkshop
Re: Simple QRTP
« Reply #5 on: February 06, 2015, 05:24:20 AM »
Hi Bill,
I really like this idea.
I know it is a long time since you originally posted but can you give an update on how it has performed. Would you change anything?
Kind regards
Mike
Re: Simple QRTP
« Reply #6 on: February 06, 2015, 06:55:46 AM »
As you tighten the Allen bolt, I presume the slots closes up? This in turn grips the holder? ( think I'm missing summat here.....)
Nice bit of machining btw.....
Ah... The light comes on :doh:....push instead of pull... :lol:
Offline drmico60
    • mikesworkshop
Re: Simple QRTP
« Reply #7 on: February 06, 2015, 07:13:08 AM »
I think the screw pushes the slit apart and expands the dovetails that grips the holder.
Mike
Re: Simple QRTP
« Reply #8 on: February 06, 2015, 07:15:00 AM »
Yeah...I figured that with a bit of help from a fellow flier.....( where's the embarrassed smiley?)
Offline Bill Stupak
Re: Simple QRTP
« Reply #9 on: February 07, 2015, 08:27:33 AM »
Kind regards
Mike
Hi Mike, The design didn't work as expected, it never held the tool holder tight enough. I fiddled with it a bit, but couldn't get it to where I was confident it would hold. I still think it's a viable design though and with a different pitch bolt and re-positioned slit it might work.
Offline drmico60
    • mikesworkshop
Re: Simple QRTP
« Reply #10 on: February 08, 2015, 04:40:02 AM »
Hi Bill,
Thanks for the update. I may have a go at trying to get it to work.
Mike
Offline Bill Stupak
Re: Simple QRTP
« Reply #11 on: February 11, 2015, 11:12:28 AM »
Mike, if you do, post it up, I'd like to see what you come up with.
