Author Topic: Potty Lads and Dads Engine  (Read 63707 times)
« on: April 15, 2013, 09:10:08 AM »
I have an old works friend who's just getting started in Model Engineering along with his 11 year old son who's his showing a great interest in engines with a developing tallent for 3D CAD. Chatting to them got me thinking about an engine that could be built in a relative short time with limited equipment and I came up with the simple mill engine design that I showed the drawings her http://madmodder.net/index.php/topic,8128.0.html (be warned it has mistakes) that a Dad or Grandad could make together
Hence Lads and Dads.
The design is based on this engine that I saw at the Northern Mill Engine Association at Bolton at their Christmas steam up.
http://www.nmes.org/
http://i431.photobucket.com/albums/qq32/sbwhart/IMG_3918_zps6799dda3.jpgPotty Lads and Dads Engine
I've used standard bar stock size to eliminate milling along with a piston valve, the fly wheel can be a standard 4" Stuart wheel or a fabricated one, I will also use lower cost material avoiding as must has posible copper based alloys.
Any way thats enough of that lets get on with the job,
You will need a small lathe an 1/2 decent drill with a good drill vice and some way of accuratly marking out like this
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00035_zpsc9d4a069.jpgPotty Lads and Dads Engine
Just a cheep dig caliper with the legs cut back to form a set of odd legs
First Up the steam chest from 5/8 square ally. Cut a chunk off the bar face off to length in a four jaw and mark out the position for the piston valve.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00038_zps6cbde181.jpgPotty Lads and Dads Engine
The back into the four jaw and using a wobble bar set the centre pop running true
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00041_zps7d9194b7.jpgPotty Lads and Dads Engine
Deep centre drill then to avoid the use of expensive reamers drill through with a 5.9mm or a 7/32 drill this will cut over size and make the hole near to dam it 6mm, if the bar you're going to make the piston velve out of is a bit tight just lap it down for a nice slide fit.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00045_zpse9649c9f.jpgPotty Lads and Dads Engine
Then accuratly mark out the position for the inlet ports don't centre pop them, into the drill vice and line up with a sticky pin this is just a pin held onto the chuck with platercene and nudged until it runs true. Clamp the vice to the drill table
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00046_zpsb47dacd4.jpgPotty Lads and Dads Engine
The start with a small centre drill then follow up with a 3mm drill, don't unclamp the vice from the table just losen the jaws and slide the job along to line up the second hole again with the sticky pin a drill that one, do the same with the exhaust holes.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00055_zps1d1dfc36.jpgPotty Lads and Dads Engine
Mark out for the position of central inlet fead, and the 2mm dia clamp down holes, you don't need the sticky pins to line these holes up as their positions are not as critical just use the centre drill.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00057_zps03f89056.jpgPotty Lads and Dads Engine
Thats it job done, just a few more holes to drill in it off the inlet and rod gland fixtures when they are made.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00058_zps5cbd6bcd.jpgPotty Lads and Dads Engine
The deburing tool is what my late Dad made I can tell he made it as it's got his personality writen all over it.
Offline Dan The Man
  • How did they build the first Lathe????
Re: Potty Lads and Dads Engine
« Reply #1 on: April 15, 2013, 12:56:52 PM »
 :D This is a good idea Stew!! :) i'm going to do it with my Dad wink wink
« Reply #2 on: April 15, 2013, 03:55:42 PM »
Nice one Stew   :bow: Errr....'Av'nt I seen this one before :lol:
Dan the Man,
Welcome,how about an intro from yourself? Let us know a bit more about you :thumbup:
« Reply #3 on: April 15, 2013, 08:43:44 PM »
Great thread! I really appreciate the minimum tool expense approach. Looking forward to this one!
« Reply #4 on: April 17, 2013, 05:42:07 AM »
Thanks for your interest Dan/John and vtsteam
A couple more bits finished off this morning up bright and early before six and a good 3 1/2 hrs in the shed, while it was quete (heaven  :headbang:)
Whilst i'd got the four jaw in tha lathe I quicly made the square base bit this was just a simpler vertion of the steam chest, so no pics.
Then got started on the end covers, I made both covers at the same time but you may choose to make them one at a time.
First job chunk of 35mm ally bar in the lathe face off and rough out the OD then just mark the centre with a small centre drill, black the end up, and using as et of deviders mark the PCD for the four clamping down bolts, then to mark the holes position on the PCD using one of those digi protractor thing stick it onto one of the jaws (they are magnetic) zero it up and scibe a line across the centre, rotate the chuck so that it reads 90 and scribe another line across thats it you've got the hole positions marked out, no fancy kit required. If you havn't got a digi thing you can do the same trick with a spirit level.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00064_zps73a2c085.jpgPotty Lads and Dads Engine
Then don't remove it from the chuck take the chuck off the lathe and clamp it to the drill table locate on the position centre drill then drill to required depth I drilled it deep enough to make both.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00069_zps21704f05.jpgPotty Lads and Dads Engine
Put the chuck back onto the lathe, and turn the 16mm register for the cylinder, I did this with a part off tool then zeroed the dial and cut a groove down to the zero in the position for the second cover.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00072_zpsc3e538d3.jpgPotty Lads and Dads Engine
Part the First cover off.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00077_zps7668e55b.jpgPotty Lads and Dads Engine
Then turn the features for the piston rod gland drill and tap M6 and part off
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00078_zps3a952425.jpgPotty Lads and Dads Engine
Job Done
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00085_zps9edb28e3.jpgPotty Lads and Dads Engine
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00082_zpsef72fa05.jpgPotty Lads and Dads Engine
« Reply #5 on: April 17, 2013, 09:34:17 AM »
A matching pair of covers. Made with the minimum of machining/ setting.  :thumbup:
Nicely done Stew!  :clap: :clap:
« Reply #6 on: April 17, 2013, 10:27:39 AM »
I have told you before, your an artist  :thumbup: :thumbup: :thumbup:
Offline Pete49
« Reply #7 on: April 17, 2013, 11:36:42 PM »
mmmm this looks familiar. I'll pull up a chair and watch. :clap:
« Reply #8 on: April 18, 2013, 01:00:49 PM »
Cheers Guys
On with the cylinder, I had a bit of 31.5 mm diameter ally in my stash a little undersize, but if I didn't clean up the OD I recon it will do the job, so faced a chuck off to lenth, then drilled and bored it out 16mm ID
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00087_zps0d998af6.jpgPotty Lads and Dads Engine
The using the four jaw with the cylinder longwise face off one side for valve chest.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00090_zps7f8cb89c.jpgPotty Lads and Dads Engine
Turn it round 90 check that its square and face another side off for the base
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00091_zps88aea61b.jpgPotty Lads and Dads Engine
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00092_zps24f9f120.jpgPotty Lads and Dads Engine
Over onto the drill and drill the ports
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00097_zps317b8f35.jpgPotty Lads and Dads Engine
The spotting off the valve chest drill and tap M2
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00101_zpsb60d92a0.jpgPotty Lads and Dads Engine
Then from the end face drill down 3mm into the inlet port.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00102_zpsdbf0279b.jpgPotty Lads and Dads Engine
The use the end covers to spot through for drilling and tapping M3 for the end cover fixings.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00105_zps4ae8a572.jpgPotty Lads and Dads Engine
Thats the cylinder done
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00107_zps82238d66.jpgPotty Lads and Dads Engine
Time for a quick assembly of parts to see how its looking
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00108_zpsd751da35.jpgPotty Lads and Dads Engine
MMMMMMMMMMMMMMM  not bad
« Reply #9 on: April 18, 2013, 01:05:57 PM »
"MMMMMMMMMMMMMMM  not bad".
That's a bit of an understatement young man.......  :scratch:
Blummin well done Stew!  :clap: :clap:
« Reply #10 on: April 19, 2013, 10:06:29 AM »
Cheers Dave
The boss has been working today standing in for a sick teacher, so had the day all to myself in the shed, almost done an 8 hrs shift so when i've done this i'm going to have a nap.
Made the stuffing box for the valve rod
Drilling out the top hat bit
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00109_zpsb8426bcd.jpgPotty Lads and Dads Engine
Spot drilling through into the valve body for to fix the valve guide.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00110_zps071bea60.jpgPotty Lads and Dads Engine
Shaping up thr valve guide
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00117_zps31698a06.jpgPotty Lads and Dads Engine
Turing up the valve from a bit of 6mm stainless.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00127_zps965f8226.jpgPotty Lads and Dads Engine
These are the valve bits
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00132_zpsdbb9ecde.jpgPotty Lads and Dads Engine
Also turned up the piston and piston rod guid this is the only pic I took.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00133_zps54d5b94e.jpgPotty Lads and Dads Engine
And the bits lose assembled
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00135_zpsc43b7b5e.jpgPotty Lads and Dads Engine
« Reply #11 on: April 19, 2013, 04:57:09 PM »
hi work is well dun keep it up i will have to get myself one of them angel gage
« Reply #12 on: April 20, 2013, 07:57:30 AM »
Cheers krv3000
this mornings job was to make the con rod. Cut a length off 1/4*5/8 mild steel bar allowing a little extra on the length.
Mark it out then drill the hole for the bearing, to get it flat place the bar on the table put the vice over the top and clamp up on the bar, that it nice and level with the top of the vice.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00136_zpsda6e7c8e.jpgPotty Lads and Dads Engine
Drill 8mm
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00137_zps9bf4a57c.jpgPotty Lads and Dads Engine
Then centre drill each end for turning between centres
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00139_zps052df283.jpgPotty Lads and Dads Engine
Its a bit of a awkward shape for fitting a drive dog to so,
With the four jay self centering chuck turn a 6o deg point on a bit of bar.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00142_zpsbdb125c5.jpgPotty Lads and Dads Engine
Set this back in the chuck then with a life centre in the tail stop, the chuck jaws act as the drive dog.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00143_zpsb31e6927.jpgPotty Lads and Dads Engine
Rough the material out rough shape and face the end to length leaving a pip.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00144_zpsae11d7bd.jpgPotty Lads and Dads Engine
Slew the compund round 3 deg then with a radius tool finish off
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00146_zps7f62e7c1.jpgPotty Lads and Dads Engine
Flip it round and turn the other end at the 3 deg setting.
A bit of work with a filing button and drill and tap for fixing the brasses and its
Job Done
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00147_zps227131b1.jpgPotty Lads and Dads Engine
« Reply #13 on: April 20, 2013, 01:08:54 PM »
Excellent work! Great to be able to follow along.  :thumbup:  :clap:
« Reply #14 on: April 20, 2013, 03:44:08 PM »
Great work very well shown
« Reply #15 on: April 20, 2013, 04:36:12 PM »
Looking good so far Stew...... :thumbup:
Are you planning on doing the same sort of thing for a boiler?  :scratch:
« Reply #16 on: April 22, 2013, 05:01:41 AM »
Thanks chaps
No John I have no plans for fitting it to a boiler, I doubt my choice of materials would make it suitable for steam running.
Onwards and Upwards with the bearings housings.
These are made from 5/16 thick bar not 1/4 as in the drawing i thought 1/4 would look a little flimsy.
Fist job measure the height of the piston rod to make the bearing centre height the same, then cut a couple of chuncks of the bar roughly square the ends up with a file and mark them out then as for the con rod centre drill the ends for between centre turning, I cut some of the surplus material off by hacksaw first then on to the lathe for facing off to length and turning to shape.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00153_zpsfca89cbb.jpgPotty Lads and Dads Engine
For the next bit I desided to fit my vice stop to my new drilling vice this was just a mater of drilling and tapping a M6 hole into the side of the vice.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00151_zps13066298.jpgPotty Lads and Dads Engine
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00149_zps417ee988.jpgPotty Lads and Dads Engine
Then onto the drill for drilling the 12m hole for the bearing I made sure that the base of the bearing was up against the fixed jaw and that the vice was firmly bolted down and the stop set.
Drill the first housing then without unbolting the vice drill the second again with its base up against the fixed jaw this way the centre height will be the same for both housings.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00156_zps97e2676a.jpgPotty Lads and Dads Engine
Then drill the bolting down holes 2.5mm dia again taking advantage of the vice stop, I wish I'd added this before I started.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00157_zps001c3db0.jpgPotty Lads and Dads Engine
The give them a good seeing to with a file and filing button the shape the top
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00160_zps3fcded1b.jpgPotty Lads and Dads Engine
Turn up the bearing.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00161_zpsac43e7e2.jpgPotty Lads and Dads Engine
Fit them in place with some loctite
and its another job done
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00162_zpse1e517e1.jpgPotty Lads and Dads Engine
« Reply #17 on: April 22, 2013, 07:36:04 AM »
Bit more done:- the Cross head
Made from a bit of oblong section bar, start by marking the centre on a end face accuratly centre pop the position.
The using a wobble bar centre it up using a four jaw independant chuck.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00164_zps7e8d1a9d.jpgPotty Lads and Dads Engine
Turn a step up centre drill and tap M4 for the piston rod.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00166_zps618c2c1f.jpgPotty Lads and Dads Engine
Keeping it on the bar helps you to securly clamp it, drill a couple of hole to form the slot.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00169_zps5dfbc229.jpgPotty Lads and Dads Engine
Flip it on its side and drill for the end pin.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00171_zps26161872.jpgPotty Lads and Dads Engine
Then cut it off the bar hacksaw the slot and file to fit
And its another one done.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00174_zps6e02ae41.jpgPotty Lads and Dads Engine
« Reply #18 on: April 24, 2013, 06:17:28 AM »
A few more parts done,
First up the bearing brasses:- drill the clamping holes in some 1/4" brass square bar
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00176_zps7a165ea1.jpgPotty Lads and Dads Engine
Then bolt them too the con rod mark the centre line and drill and ream through 6mm dia
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00178_zps3bbe63c4.jpgPotty Lads and Dads Engine
Then make the end plat sorry no pics for that bit.
Then make the little end gudgion pin
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00189_zps6b3a912c.jpgPotty Lads and Dads Engine
The the slide bars to get the M4 tap square I light held the tap in the chuck jaws just enough to keep them square but not enough to stop it turning in the chuck then with the wrench clamped on the parallel bit of the tap start the tap nice and square, and remove the job from the vice to finish it off.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00192_zps4018988d.jpgPotty Lads and Dads Engine
Thes are the bits
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00197_zps4afb413f.jpgPotty Lads and Dads Engine
And how they assemble
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00194_zpsc4b2dc7c.jpgPotty Lads and Dads Engine
« Reply #19 on: April 24, 2013, 09:32:01 AM »
Beautiful work  :thumbup: :thumbup: :thumbup:
« Reply #20 on: April 24, 2013, 11:48:27 AM »
Crackin' components, nicely produced and shown.  :thumbup:
Well done Stew!  :clap: :clap:
« Reply #21 on: April 24, 2013, 05:29:53 PM »
I think you have done this before  :lol: :lol: :lol: :lol: :lol: :lol:
Very nice work  :bow: :bow: :bow: :bow:
Well shown as well
« Reply #22 on: April 26, 2013, 10:44:59 AM »
Thanks for the support Lads  :thumbup:
Yes John I think you may be right, the engine is certainly comming together quickly the end is in site  :D
I ordered a chunk of 1/4"* 3" ally plate from ebay, for the bed plate I first carfully marked out the position for the cylinder assembly i had to drill and tap 2 more m3 hole into the cylinder base to fix it I intended to screw to go right through the bed plate through the cylinder base into the cylinder but my M3 countersunk cap screws were too short for this hence the extra holes.
Drilled and countersink the bed plate.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00198_zps3dfb0fb7.jpgPotty Lads and Dads Engine
Then made the crodd head slide bars from some 1/4" squ mild steel bar, I put the drill vice stop to good use to get them all drilled the same with the stop set and the vice clamped to the table it it just a matter of setting up on the first then driiling it then dito for the rest having first made shure they were all the same length.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00202_zps5e80e7bc.jpgPotty Lads and Dads Engine
Then the spacers were made I just truned a length up enough to make three centrree drilled then drilled through 2.5 than carfully parted them all off to the same length. No pics
Then it was the turn for the supporting pillars it important that these are made to match the assembly so a took my time and measured the centre height of the piston and did a bit of a calculation to get their heght (29.4mm). I made them from some brass hex bar i had in my stash, first I parted four off 31mm long faced and tapped one end M3 and did the same to the other end but M2.5. These pillars need to be all the same exact length, so I fitted my back stop into my lathe head stock.
This is the beast its just a No 3 morse taper with an M8 hole one end for the stops, and a M10 in the other for a draw bar.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00212_zps6cb223d8.jpgPotty Lads and Dads Engine
And it in the lathe
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00209_zps3c30f51b.jpgPotty Lads and Dads Engine
And with the chuck mounted.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00208_zps6a23c865.jpgPotty Lads and Dads Engine
It was just a mater then of setting the sadle facing off at the same setting, to make them all the same allowing .5 for final finished, put on the final .5 flip them round and face off job done.
I then turned a parallel to just leav a short length of hex.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00204_zpse37b563a.jpgPotty Lads and Dads Engine
I then carfully marked the position to driil the holes for the pillars in the bed plate ensuring there was enogh room to tkae up the travel of the cross head etc, and then drill and chamfered the bed plate to take m3 countersunk cap screws to hold them
To ensure the valve rod support lined up with the rod a turned a point on a bit of 3mm silver steel mounted it in the valve chest and gave the support a light biff to mark the position for the hole.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00213_zpsf1814eae.jpgPotty Lads and Dads Engine
Time for a few hows it looking shots.
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00214_zps0b9b03ca.jpgPotty Lads and Dads Engine
Not bad just the crank eccentric and the fly wheel to make.
« Reply #23 on: April 26, 2013, 12:10:22 PM »
Looking pretty good Stew!  :bugeye:  :clap:  :clap:
In fact, quite professional......  :thumbup:
« Reply #24 on: April 27, 2013, 01:32:21 PM »
Cheers Dave
The Boss was has been away all day visiting an old school friend, so I was in pigs heaven, all day in the shop.
First bit the crank shaft, turn up and thread the end and cut off
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00218_zps158040df.jpgPotty Lads and Dads Engine
Next bits the crank webs, made from 1/2"*1/4" mild steel bar cut off a couple of bits allowing a bit for cleaning up, then mark out
http://i431.photobucket.com/albums/qq32/sbwhart/Lads%20and%20Dads%20engine/DSC00222_zpsa6d4585e.jpgPotty Lads and Dads Engine
Then drill both 8mm
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00224_zpsacea79bd.jpgPotty Lads and Dads Engine
Then stick a bit of 8mm bar through both bits and then drill 6mm hole this way the hole centres will be exactly the same for both bits.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00225_zpsc645e659.jpgPotty Lads and Dads Engine
Then turn up a 8mm mandrell
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00228_zps4c358012.jpgPotty Lads and Dads Engine
Mount both bits to the mandrel tighten up tight abd skim down the ends to form a nice rad
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00230_zps05c5a18a.jpgPotty Lads and Dads Engine
Turn the mandrell down to 6mm mount the bits back onto it and turn the other end down.
Give both parts a tidy up and a polish
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00234_zps5bb9cd2a.jpgPotty Lads and Dads Engine
Then with high strength loctite assemble the crank shaft and cronk pin.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00235_zps6d99f69c.jpgPotty Lads and Dads Engine
Just to make sure drill and pin the webs in place.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00240_zps3a9cadb6.jpgPotty Lads and Dads Engine
For the pins use nails cut off just a little longer than required and rivet in place and clean up, and cut out the middle bit of the crank shaft.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00241_zpsb61929cf.jpgPotty Lads and Dads Engine
Next bit the eccentric to avoid the use of a milling machine this is fabricated in two part plus the eccentric sheath.
Luckily I had a bit of brass tube that was near to dam it the corect size all I had to do was part a ring off, and drill and tap M3 for the shaft.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00238_zps96b814fd.jpgPotty Lads and Dads Engine
The eccentric first part was a top hat outer part.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00244_zpsb394ef8b.jpgPotty Lads and Dads Engine
Then the inner part this as the off set for the throw.
Turn up dia for assembly to the top hat bit
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00248_zpsa64b15bf.jpgPotty Lads and Dads Engine
Try the fit
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00249_zpsc76ab830.jpgPotty Lads and Dads Engine
Flip it round in the chuck face to thickness and put in a small centre.
Then mark out the throw.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00250_zps29c178de.jpgPotty Lads and Dads Engine
Set it up with a wobble bar
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00251_zps527818f9.jpgPotty Lads and Dads Engine
Drill and ream
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00252_zpse790398f.jpgPotty Lads and Dads Engine
Turn up the boss
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00255_zpsf020b559.jpgPotty Lads and Dads Engine
And stick the bits together with high strength loctite
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00256_zps45469871.jpgPotty Lads and Dads Engine
And a try for fit of todays bits.
http://i431.photobucket.com/albums/qq32/sbwhart/DSC00258_zps5d567de7.jpgPotty Lads and Dads Engine
