Author Topic: CNC Lathe Conversion  (Read 12990 times)
Offline andre
« on: April 12, 2013, 12:38:22 AM »
Hi guys My Name is   Andre I turn  this year. For my major high school project I am converting Myturn sl7 lathe to CNC.
Re: CNC Lathe Conversion
« Reply #1 on: April 12, 2013, 05:43:54 AM »
Hi Andre
Cool project ,  :thumbup:  I hope you share doing the conversion with us here on Madmodder  :poke:
Offline andre
« Reply #2 on: April 12, 2013, 08:24:58 AM »
I have started the bracket which will bolt to the rear of the lathe and hold the stepper motor. I also need to fit thrust bearing to the lead-screw although I am not to sure how to do this  :scratch:
laying out holes in the mill
Hole sawing excess stock
Using Boring head as a flycutter to make a slot
« Reply #3 on: April 12, 2013, 08:31:09 AM »
Offline andre
« Reply #4 on: April 12, 2013, 08:34:50 AM »
Making the section which will actually attach to the lathe. I had to mill out a groove the allow the bracket to sit on the raised section of lathe bed.
« Reply #5 on: April 12, 2013, 11:35:13 AM »
Andre, very interested in this one. Thanks for sharing!
John Stephenson, excellent link!
 :mmr:
Offline andre
« Reply #6 on: May 11, 2013, 10:28:03 PM »
Okay I have installed the thrust bearings onto the lead screw and boy what a difference it makes I can now move the carriage by turning the lead screw with one finger  :)
I then machined a new bush for the end of the shaft with two flats and a thread to replace the previous nut and collar arrangement It will also give me a shaft to mount the lead-screw drive pulley on.
« Reply #7 on: May 12, 2013, 05:26:47 AM »
Just a heads up but that is not a Myford ML7 lathe but one of the Taiwanese clones. Not that it matters but there may be slight differences for anyone following on.
ML7 has split plain spindle bearings.
These were often marketed at Colt lathes.
see the last photo's at the bottom of this page.
http://www.lathes.co.uk/myford/page15.html
