Author Topic: Clare collet holder help!  (Read 11205 times)
Offline andythesquirel
« on: April 01, 2013, 04:17:00 PM »
I've recently picked up a CLARE A490 (size A) boxed collet chuck set, in very good condition. It contains 3 imperial collets, and a 1MT collet, and the collet chuck has a 2MT shaft with a female threaded end.
Firstly, does anyone know the shaft end thread size? (I have got this to use on my Centec mill as it has a lower height to the table than my Clarkson collet chuck, but I need to know the correct thread so I can make a new drawbar).
Secondly, can someone confirm the correct way to insert the cutters and tighten them in? (The collets accept plain shank cutters, or old ones with a tang at the end, and the collets have a thread to screw to the end cap. The end cap also screws to the main body. However, there is also a washer in the box. Is this part of the set, and if so, how does is it used?)
Any help would be appreciated - Thanks - Andy
Re: Clare collet holder help!
« Reply #1 on: May 22, 2013, 12:20:35 PM »
Hi MadModders
Recycling this thread. Someone must know something about this.  :D
« Last Edit: May 22, 2013, 04:11:24 PM by dsquire »
« Reply #2 on: May 22, 2013, 03:35:47 PM »
For MT2 it is either 10 mm or 3\8 Whitworth for a draw bar .
« Reply #3 on: May 22, 2013, 04:16:11 PM »
Hi MadModders
Is this a new fetish you've got ?? ie Trawling through the archives ??   :loco:   :loco:   :lol:   :lol:    :lol:
Anyway, my bit ... When I got the S7 I had some Clare Collets, no use to me, I sent them to a member of M E C H
He lives in Lincoln IIRC.
http://modeleng.proboards.com/index.cgi
So Andy, I don't know if you are registered there, but at least one geezer on there uses them ...  :thumbup:
( Unless he wanted them for catapult ammo or something )
Not much, I know ...  :(  but it may help ..
Dave BC
« Reply #4 on: May 22, 2013, 05:39:54 PM »
Dave BC
I've got to have something to do on my trips around the sun. Beside that, it helps to keep your mind sharp and your wit quick which is a good thing, I think!  :lol: :lol: :lol:
