Author Topic: Lathe spindle atatchments  (Read 12107 times)
Offline modeldozer
  • Valencia, Spain
    • AJ´s Truckmodeling
« on: March 31, 2013, 08:33:04 AM »
Hi all,
For some time I wanted to make some attachments to fit on the back end of the lathe spindle.  As there are various and there are no threads left on the end of my spindle, a different idea was needed.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1845.jpgLathe spindle atatchments
After looking at what others have done I came up with the idea to make a permanently installed extension/spider and some accessories to fit onto it.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/SpindleAtch2.jpgLathe spindle atatchments
I was concentrating on the making of the parts so much I forgot to take build photos, so these are of the finished parts.
The extension.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1848.jpgLathe spindle atatchments
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1859.jpgLathe spindle atatchments
The indexer hub with a gear fitted.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1857.jpgLathe spindle atatchments
The indexer detent assembly.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1865.jpgLathe spindle atatchments
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1867.jpgLathe spindle atatchments
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1869.jpgLathe spindle atatchments
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1871.jpgLathe spindle atatchments
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1872.jpgLathe spindle atatchments
The hand crank.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1851.jpgLathe spindle atatchments
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1861a.jpgLathe spindle atatchments
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1861b.jpgLathe spindle atatchments
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1875.jpgLathe spindle atatchments
And all together.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/SpindleAtatchment/DSCN1878.jpgLathe spindle atatchments
I have used the indexer, spider and hand crank a few times and can not think how I worked without them in the past.
Cheers.
Abraham
Re: Lathe spindle atatchments
« Reply #1 on: March 31, 2013, 01:37:09 PM »
Oh my! you have been a busy little bee..... :dremel:
Nice touch with the indexer detent....
« Reply #2 on: March 31, 2013, 02:45:11 PM »
Nice work, Abraham :clap: . I too like the detent. Is there enough travel on it to accommodate different sizes of gear? I think your pic shows 50T, which is OK for 2, 5, 10, 25 and 50 divisions, and a 48T would get you 3, 4, 6, 8, 12, 16, 24 and 48 in addition. Looking at the lower numbers, I don't suppose you'd need 7, 9, 11, 13, 14 or 15 very often.
Offline modeldozer
  • Valencia, Spain
« Reply #3 on: March 31, 2013, 03:10:08 PM »
Thanks guys.
Andy.
as the outer housing off the detent can slide in the support it can be adjusted for different gears.  It was tested from the smallest to the largest (80) change gears off the lathe.
Abraham
« Reply #4 on: March 31, 2013, 06:25:49 PM »
well dun
Offline Lykle
« Reply #5 on: April 03, 2013, 08:21:56 AM »
OK, yes, thank you. Another plan to build.
This one I will have to do.
Question for you, on some of the pics it looks like you have a left handed lathe. The pic showing the indexer in position.
There are control levers to the left of that and I can see the chuck, but do you have control levers on the back of your lathe?
Zooming in, the word Stop does not seem to be in mirror image so you have me puzzled.
Lykle
Lykle
Design, Build and Enjoy life.
« Reply #6 on: April 03, 2013, 11:39:10 AM »
Good work!  :clap:
Offline modeldozer
  • Valencia, Spain
« Reply #7 on: April 04, 2013, 08:15:07 AM »
Thanks to all for their kind remarks.
Lykle,
No, it is not a left hand, the lever you see is the low /high speed gear lever, at the back of the headstock.  The lathe is a highly modified 7x1214 Real bull clone.
Abraham
Offline Pete49
« Reply #8 on: April 04, 2013, 10:19:02 PM »
Now that's some good ideas worth pinching :beer: Amazing what a little thought can do to cheapo lathes  :mmr:
Offline steamer
« Reply #9 on: April 13, 2013, 07:13:39 AM »
Sorry I missed this one!   Nice!
I'm in need of doing something similar for the SB.
Thanks for posting that!
"Mister M'Andrew, don't you think steam spoils romance at sea?"
Damned ijjit!
