Author Topic: D.T.I stand refit  (Read 24904 times)
D.T.I stand refit
« on: March 30, 2013, 07:50:12 PM »
hi all well i had a full day in the workshop today and i had a project i have had the stand for sum time the magnet in it was OK so it was worth fixing up first job get the magnet out to my surprise it just came strate out the next job was to clean it up i removed as much of the old pant by hand then set it up in the 4 jaw chuck to clean the sides off then i had to mack up a front cover plate i made this out of a peace of aluminum plate 4mm thick i drilled the center out then with me boring bar bored out the hole to 32mm then i had to put a step in 2mm deep by 38mm wide this is for the device that will rotate the magnet right pics
Re: D.T.I stand refit
« Reply #1 on: March 30, 2013, 08:16:29 PM »
 i had a rummage and fawned sum plastic that will become the rotating device for the magnet i turned the out side diameter dawn to 38mm that's the sises of the hole that the magnet fits in to then i had to put a step in it to go threw the plate for the front then i needed to cut the slot out for the magnet to fit in to witch is 20mm wide by 7mm deep by hand this proved to be harder than expected once that was dun i had to put a slot in the front of the device this will be for the nob to rotate the magnet simple this time the slot is 8mm wide by 4mm deep i just cut the sides out then with a wood chisel cut the center out then made up a peace of brass that will be fitted for the nob and two stops putting in i marked of all 4 corners and drilled 1.6 then taped 2mm to fix the front plate on right More pics
« Reply #2 on: March 30, 2013, 09:34:14 PM »
kv300, you ought to be on television!    :bow:
Have your own make-over show. I mean it. I'd watch every episode.
Snazzy looking paint job, btw.  :headbang:
« Reply #3 on: March 31, 2013, 02:24:52 AM »
More junk, re formed into jewellery!  :bugeye:
Blummin well done, Bob!  :clap: :clap:
« Reply #4 on: March 31, 2013, 05:19:03 AM »
nice going Bob  :clap: :clap: :clap: :thumbup:
Offline Fredbare
  • Fakenham, Norfolk
« Reply #5 on: March 31, 2013, 12:08:16 PM »
Another silk purse from a sows ear, well done Bob, and thanks for sharing.
Offline rudydubya
« Reply #6 on: March 31, 2013, 05:57:54 PM »
Well done Bob.  I always enjoy and learn something from your fixes.   :clap:
Regards,
Rudy
« Reply #7 on: March 31, 2013, 06:21:54 PM »
thanks all for the coments
« Reply #8 on: March 31, 2013, 06:31:03 PM »
Another quality fix by Bob  :clap:, I will be looking forward to the next item to be saved by Dr Bob ............. even when something has no pulse Bob can save it  :lol: Keep up the good work.
  Cheers Mick
« Reply #9 on: April 01, 2013, 02:17:39 AM »
           Great Job,
                                         Cheers  David
