Author Topic: How do I fix Petrobond  (Read 12496 times)
Offline stevehuckss396
« on: March 24, 2013, 01:41:17 PM »
I bought 100 pounds of petrobond about 2 years ago and have just gotten around to using it. It seems a little wetter than I thought it would be and seems to crumble easier than it should. I need to do something to it to get it to firm up and stay together better. I have a small cement mixer, I was thinking of tossing it in there and giving it a twirl thinking the oil may have migrated to the bottom of the box. That might get everything mixed up and evened out. If that fails should I add a binder. bentonite? cat litter?
How can i fix the sand?
http://i770.photobucket.com/albums/xx349/stevehuckss396/MDMCEngine/DSCN0668.jpgHow do I fix Petrobond
Re: How do I fix Petrobond
« Reply #1 on: March 24, 2013, 02:01:01 PM »
I would give it a good mix up
Mine has been in a bag 3 years and still works fine
Offline bob ward
« Reply #2 on: March 24, 2013, 02:59:39 PM »
Giving your petrobond sand a whirl in a cement mixer should improve things, remulling it is a better option, but if you had a muller you wouldn't be talking about cement mixers.
OTOH adding bentonite, kitty litter etc will create problems for you as they are not oil compatible.
« Reply #3 on: March 24, 2013, 03:12:41 PM »
Well then i'll find out what a muller is and build me one. Thanks!
« Reply #4 on: March 24, 2013, 03:31:48 PM »
ironman has a great muller design.
« Reply #5 on: March 24, 2013, 03:41:27 PM »
From what I have read a muller is a mixer with a few shot put or cannon balls in it.  No need to build one.
