Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Project Logs
Home
Help
Search
Login
Register
The Shop
Tools
What Insert is This???
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: What Insert is This??? (Read 10465 times)
ibuildstuff4u
Full Member
on:
March 11, 2013, 03:52:06 PM »
My new lathe came with some nice indexable tool holders but I don't know what size the inserts are to order replacements. The tool holders are 1/2" shaft and to me the inserts look like DCMT or DCGT 21.51? The insert has an IC 20 printed on the top and I have included some measurements in the photo below. I placed it next to a TNMG 322 insert for size comparison.
I would like to buy some replacement inserts cutting aluminum if someone has any suggested types.
The square insert also came with the lathe and I'm interested to know what type of insert this is too if any one knows.
Thanks for the help!!!
Dale P.
Logged
NeoTech
Hero Member
Re: What Insert is This???
Reply #1 on:
March 11, 2013, 04:21:41 PM »
DCMT 11T3xx most likely. =)
Logged
Machinery: Optimum D320x920, Optimum BF20L, Aciera F3. -- I have not failed. I've just found 10,000 ways that won't work.
http://www.roughedge.se/blogg/
ibuildstuff4u
Full Member
Reply #2 on:
March 11, 2013, 04:33:43 PM »
I just found a chart showing the size of a 21.51 insert and 32.51 insert and appears to be a 32.51 . Dam I wish I knew more about inserts and their different codes. Looks like a DCGT, DCMT, DCGW, DCET insert all have the same profile, just made for different uses?
What is the difference between a 32.51 and a 11T3 ?
Dale P.
Logged
Guest
Reply #3 on:
March 11, 2013, 04:40:19 PM »
Hi Dale
I have attached a TCT chart ,,,,,,,,may help
Logged
ibuildstuff4u
Full Member
Reply #4 on:
March 11, 2013, 08:25:48 PM »
Thank you! That's just what I needed and answers a lot of questions I had about how inserts were coded.
Thanks again,
Dale P.
Logged
rdhem2
Jr. Member
I LOVE SWARF!!!
Reply #5 on:
April 20, 2013, 11:16:33 AM »
Kind Sir;
Check out
carbidedepot.com/resources.htm
. Go to milling, tech notes.
They sure explained a lot for me.
Good luck.
Logged
Russ
Print
Pages: [
1
Go Up
« previous
next »
The Shop
Tools
