Author Topic: New Video  (Read 23583 times)
New Video
« on: March 09, 2013, 06:10:24 PM »
Lads
Been playing with the new camera
Any one done any welding video
« Last Edit: March 10, 2013, 02:28:26 PM by dsquire »
Re: New Video
« Reply #1 on: March 09, 2013, 07:04:35 PM »
 Good video John  :thumbup:  , that galvie is rancid stuff eh , its hard to get it all ground off too so even when you think its gone its not and still stinks .... looking forward to part two  :clap:.
   Cheers Mick
Offline fixerup
Re: New Video
« Reply #2 on: March 09, 2013, 10:10:17 PM »
Hi John,
I was told that welding galvanized material was really bad for us. Please get some good ventilation going ,because I like your video and would like to see more.
Re: New Video
« Reply #3 on: March 10, 2013, 03:09:25 AM »
 :clap: :clap: :clap: :clap: good to see your back in the shop mate  :thumbup:
Video quality is excellent  :headbang:
Rob ,,,,,,,,,,,,,, think i have some darker shades
Offline S. Heslop
Re: New Video
« Reply #4 on: March 10, 2013, 08:03:08 AM »
Nice video. Welding is always a pleasure to watch.
Re: New Video
« Reply #5 on: March 10, 2013, 02:54:59 PM »
Nice video that you are making there. You keep making them and we will keep watching them.  :clap: :clap:
I fixed the link up so that it is embeded for you. Hope that you don't mind.
Offline Fredbare
  • Fakenham, Norfolk
Re: New Video
« Reply #6 on: March 10, 2013, 03:32:02 PM »
Great video John, looking forward to part 2
Re: New Video
« Reply #7 on: March 10, 2013, 07:54:48 PM »
I like your videos a lot doubleboost. They're real. And it's nice to see someone else working in a small shop, and using scrap -- I can identify with that.
I have the same type of metal, on hand, too. Here it's called Uni-strut I think. Used for pipe and cable hangers with all-thread. Like you I try to avoid welding galvanized. I always weld and cut outdoors, but perhaps you have neighbors closer than I do. Even outdoors you still get the fumes from galvanizing unless the wind is strong..
It's very important not to weld or cut with a torch cadmium plated hardware or chrome plated -- zinc in galvanizing is not pleasant or healthful, but those others are quite dangerous. Sometimes older painted metal has an undercoat of red lead, too. These are some of the things to be aware of when using scrap materials. Cadmium plate looks slightly gold or multicolored. Often aircraft bolts and hardware is cadmium plated.
I particularly liked your video on core making -- I've done it myself, but learned something new from your own way of doing it.
Never heard of a log crocodile. Will have to look for your next video!
Re: New Video
« Reply #8 on: March 12, 2013, 04:51:33 PM »
Nice video John. I too enjoy watching them...
 :mmr:
Offline 75Plus
Re: New Video
« Reply #9 on: March 12, 2013, 05:15:35 PM »
Regarding welding galvanized items. in high school metal shop, back in 1949~50, we had to make a tool tray from galvanized sheet metal. All the corners had to be soldered using a soldering iron, actually about a 1lb. chunk of copper, heated on a gasoline (petrol) torch. In order for the solder to stick the zinc had to be removed. This was done by brushing on muratic acid, the same acid that is used to clean brick work. The acid can be washed off after it has done its job.
Joe
Re: New Video
« Reply #10 on: March 12, 2013, 06:04:32 PM »
Clean galvanising solders quite well with 'non lead' plumbing solder. I use it to tidy up panels I bend up from galvanised 1.6mm sheet
Offline 75Plus
Re: New Video
« Reply #11 on: March 13, 2013, 10:56:10 AM »
Perhaps I should have made the point that using acid to remove the zinc, preferably outdoors, would solve the problem of the fumes from burning it during welding.
Joe
Re: New Video
« Reply #12 on: March 16, 2013, 11:29:22 PM »
« Last Edit: March 17, 2013, 02:25:55 AM by dsquire »
Re: New Video
« Reply #13 on: March 23, 2013, 03:40:38 PM »
as per brill work john  :clap: :clap: :clap:
Offline fixerup
Re: New Video
« Reply #14 on: March 23, 2013, 08:53:09 PM »
Doubleboost,
It looks like a very useful tool to have. Easy to set the log in, stable holder to cut your wood and to boot, you can fold it to store it. Well done with the video and the build.
Thanks for posting!
