Author Topic: my craftex mill won't start  (Read 11682 times)
« on: February 12, 2013, 02:17:58 AM »
I bought this mill just before xmas and it worked great but I think I may have killed its magnetic switch. I didn't have coolant on it so I put one together using a aquarium pump and picked up a flexible hose it has a magnet in its base so the best place to stick it is under the switchbox..... and it has not run since the fuse is fine but we changed it anyway and there is power to the wall socket! so what do you think can a magnet kill a magnetic switch?
http://i1322.photobucket.com/albums/u577/tom_osselton/Photobucket%20Desktop%20-%20TOM-PC/DSC_0287_zpsbe921965.jpgmy craftex mill won't start
Its a nice size and should handle anything I need!
http://i1322.photobucket.com/albums/u577/tom_osselton/Photobucket%20Desktop%20-%20TOM-PC/DSC_0295_zps7cfa3853.jpgmy craftex mill won't start
and this is killer!
http://i1322.photobucket.com/albums/u577/tom_osselton/Photobucket%20Desktop%20-%20TOM-PC/DSC_0296_zps9fb45004.jpgmy craftex mill won't start
and I put it right about where those two screws are.
« Last Edit: February 12, 2013, 02:47:32 AM by tom osselton »
Re: my craftex mill won't start
« Reply #1 on: February 12, 2013, 03:27:09 AM »
 :scratch: I suppose it is just conceivable that the nearby magnet might have opposed the solenoid in the switch relay so that the relay contacts wouldn't close. But all would be well again once the magnet was removed.
I know it's a bit elementary, but are there any safety switches on the chuck guards etc which might be open? And once the big red emergency stop has been operated, do you have to push it in and turn it (it seems to have arrows embossed on it) before you can restart?
« Reply #2 on: February 12, 2013, 03:32:20 AM »
lol that is the first thing that I did check all the buttons made sure the stop was out and power at the plug.
« Reply #3 on: February 12, 2013, 03:33:09 AM »
Tom,
Have you tried the obvious and removed the mag base?
Have you disturbed the wiring inside the housing at all (perhaps to feed your pump) ?
« Reply #4 on: February 12, 2013, 03:36:48 AM »
I have tried it with the mag off and the pump is seperate from the mill.
lordedmond
« Reply #5 on: February 12, 2013, 03:39:18 AM »
 have you checked the guard switch , maybe its been knocked
« Reply #6 on: February 12, 2013, 03:43:41 AM »
nope checked that one too i'll give them a call today when I get up I just hope they don't say to bring it in its downstairs lol
« Reply #7 on: February 12, 2013, 05:45:24 AM »
Looks like a trip to the supplier..... :zap:
Hope you get it sorted... :thumbup:
I'm off to Belfast, else I'd stick around to help... :coffee:
Offline kayz1
« Reply #8 on: February 12, 2013, 07:53:07 PM »
When my Chester V16 died it was Both the fuses in the box that had gone after a crash :doh:
 Turned out tobe one of the fuse holders shorted to earth, i replaced it and all has been fine
ever after. Not the same machine but close.
  Lyn.
« Reply #9 on: February 13, 2013, 07:18:00 PM »
 :ddb:
I've fixed my mill I took off the panel again today and checked for any power there was none even at the fuse. I pulled the fuse out and saw that there was plastic sticking higher than the contact so I cut it down a bit put it back in and it fired up so the magnetic base didn't have anything to do with it it just happened at the same time  :Doh:  thanks to all that gave  their suggestions  :beer:
http://i1322.photobucket.com/albums/u577/tom_osselton/Photobucket%20Desktop%20-%20TOM-PC/DSC_0297_zps12a9662a.jpgmy craftex mill won't start
lordedmond
« Reply #10 on: February 14, 2013, 02:39:30 AM »
glad that you have it sorted,  rubbish fuse holder
I did doubt that the mag base could have caused it as when it was on steel it would be the same as a keep on the base , no external field
Stuart
Offline kayz1
« Reply #11 on: February 14, 2013, 03:47:13 PM »
As said, mine was the fuse holder so i replaced both with good ripults parts.
