Author Topic: Source for graphite piston material  (Read 10614 times)
Offline Chuck in E. TN
  • USAF Retired
« on: January 22, 2013, 03:09:23 PM »
 I need a US source for 1” (finished)dia. Graphite for pistons for a couple of flame eaters I want to make.
Where do you get your graphite? Will this work?
http://www.graphitestore.com/itemDetails.asp?item_id=460&prd_id=25&cat_id=22&curPage=1
Chuck in E. TN
Chuck in E. TN
Re: Source for graphite piston material
« Reply #1 on: January 22, 2013, 04:41:00 PM »
Hi Chuck,
I get my graphite of ebay. I would go slightly larger than 1" if that is the finished size you need.
Offline boatmadman
  • Located in Barrow in Furness, South Cumbria
« Reply #2 on: January 22, 2013, 05:12:39 PM »
If you know someone who works in a power plant, ask if they can get you a couple of carbon brushes, they will be just the job. By the way, they are solid blocks called brushes!
Ian
If it works, take it apart and find out why!
« Reply #3 on: January 29, 2013, 03:20:40 AM »
Die sinker EDM's use graphite as electrodes - I have a box of it for my Eurospark 425 but I'm the other side of the pond from you!
Andrew
  • USAF Retired
« Reply #4 on: January 29, 2013, 07:18:23 AM »
Thanks anyway, Andrew. A mate over here came through and sent me a 1 1/2" x 1 1/2" x 3" chunk. Should do several engines.
Chuck
Chuck in E. TN
