Author Topic: circuit boards wanted  (Read 14988 times)
Offline redshift
« on: January 12, 2013, 09:07:06 AM »
Would anyone be interested in making a few boards for me, they are quite small in size ie-: 2.6"x 1". Picture is about 2x size and would need to be re-sized correctly. The unit is a driver for older type tacho's fitted to classic cars.
Regards
Re: circuit boards wanted
« Reply #1 on: January 12, 2013, 09:42:14 AM »
These people will make them for you quickly and remarkably cheaply:
http://www.pcb-pool.com/ppuk/index.html
« Reply #2 on: January 12, 2013, 10:17:56 AM »
I suggest you re-route the red trace around the top of the caps and make the board single sided.
[edit] while your at it ;) , add some side ID and version numbering  How's it mounted?
Give these guys a ring:
Lyncolec Limited.
2 Abingdon Road, Nuffield Industrial Estate. Poole, Dorset. BH17 0UG
Tel 01202 679797     Fax 01202 684530
They made me a batch of 25 PCBs (SS about eight times the size of yours) for less than £100 delivered
Offline hopefuldave
« Reply #3 on: January 19, 2013, 09:35:01 AM »
+1 on making it single-sided if poss' - it'll be a lot cheaper to produce (otherwise you'd be etching more or less all the copper off the top side). If re-routing that top side trace is awkward, consider a tinned copper wire link to make up for it?
If you stick with double-sided, put a "ground plane" over the remaining copper (with clearance around component leads) to minimise the amount to be etched away.
One more thought - mounting holes?
I've had good results ink-jet printing onto OHP transparency film, usually passing the film through the printer twice to get dense lines (with the paper guides set very carefully!), then exposing with a cheap "black light" onto photosensitive board. Some printers aren't perfect 1:1 in both axes though - it's worth making a few test prints on plain paper and adjusting to fit!
Just my ha'pennorth,
Dave H. (the other one)
