Author Topic: Milwaukee/Delta 14" bandsaw  (Read 11984 times)
Offline Banks19
« on: November 26, 2012, 07:54:14 PM »
I just got a Milwaukee/Delta 14"bandsaw serial #63-7372 and would like to know the year model. It is a complete unit with belt guard, no motor. I also need to find new tires and a motor. Can anyone help a new bee out.
Offline PTsideshow
Re: Milwaukee/Delta 14" bandsaw
« Reply #1 on: November 26, 2012, 09:38:05 PM »
1948 year    serial #'s 60-6001   -   74-6000
http://vintagemachinery.org/mfgIndex/detail.aspx?id=1141
More than you might want to know.
I have a newer one that I'm going to be adding some bling to with the Kreg fence, Carter brand tension quick adjuster brushes for cleaning the wheels and a new tension spring. Along with the Delta 6" riser kit, I have a riser kit on my Tend lines 14" band saw. It worked well.  Will be doing a how to when I get around doing the rebuild.
http://www.carterproducts.com/product_list.asp?cat_id=6 here is the web site.  :thumbup:
« Last Edit: November 27, 2012, 08:27:11 AM by PTsideshow »
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PTsideshow
« Reply #2 on: November 27, 2012, 08:36:46 AM »
IF you are in the USA, I would suggest that you go to This bookseller And get the follow DVD MASTERING YOUR BANDSAW: A Fine Woodworking DVD Workshop. any of the vid's are great.
http://www.hamiltonbook.com/tauntons-complete-illustrated-guide-to-bandsaws
Just got my copy and it is a great one. They have had a couple of other band saw titles and they also are good ones. That is if you are using it for wood working and converting it to metal use.
 :thumbup:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline 75Plus
« Reply #3 on: November 27, 2012, 09:36:29 AM »
I am running these tires on my band saw with good results. Did not require gluing to the wheels which is a plus.
http://www.grizzly.com/products/Urethane-Tire-for-14-Bandsaws-Pair-/T23070
