Author Topic: Casting aluminium with a steel core  (Read 22388 times)
Offline Lykle
« on: November 01, 2012, 01:10:08 PM »
Ah well, I knew I screwed up the moment I had poured the aluminium.
I am making a tool for my elderly father. He still likes to play golf, so I made a tool to stick the ball with tee and all into the ground, then automatically release the ball. The top of the handle is going to be an aluminium golf ball.
But it needed a hole to mount it on the carbon fibre rod of 21 mm diameter.
I had a piece of smooth steel, right diameter, so I used that as a core. And yes, now I cannot remove the steel.
Heated it, cooled it, drilled holes in it, nothing. After I had done all that, I realised that maybe I should have just tapped a M6 hole in it and mount it, embedded steel and all. Too late.
So I think I will have to cast another ball tomorrow and bore it out.
Another lesson learned.
Lykle
Design, Build and Enjoy life.
Offline jgroom
  • Kansas USA
Re: Casting aluminium with a steel core
« Reply #1 on: November 02, 2012, 12:33:40 PM »
The trick to using a steel core is to soot it up with an acetylene torch before casting.  The soot keeps the alu from sticking.  :thumbup:
Offline Lykle
« Reply #2 on: November 04, 2012, 03:04:48 AM »
If only:
I knew that before
I had a acetylene torch
I had acetylene for that matter
Oh but I do have a candle so soot is not a problem.
Thanks!
I solved it by casting a new ball.
Thanks Jeff
Lykle
