Author Topic: Myford ML10 Travelling Steady ----Machining the casting  (Read 12760 times)
« on: October 18, 2012, 03:33:45 AM »
Hi Guys
Now for the machining, there is a small area of  shrinkage on  one vertical face, so will make it a feature and  machine a  circular  depression to hide it. One my next casting I will make sure there is a big  head around  the pouring hole to compensate for shrinkage.
        David
Re: Myford ML10 Travelling Steady ----Machining the casting
« Reply #1 on: October 18, 2012, 02:24:00 PM »
Looks a good sound casting David ,,,,,,,,,,there will be no stopping you now  :thumbup:
« Reply #2 on: October 18, 2012, 04:12:11 PM »
Nothing wrong with that casting :thumbup: :thumbup:
Machined up nice :clap: :clap: :clap:
Offline Blue Chips
« Reply #3 on: October 19, 2012, 11:20:45 AM »
Looks real good, did you use any particular type of aluminum for the casting or just what was around?
« Reply #4 on: October 22, 2012, 11:11:55 AM »
Hi Guys
               Thanks for the comments. Blue chip I use scrap aluminium, but have found that to achieve a good machined finish I need to use a mix of soft aluminium eg pots and pans, and die cast items, about 50/50.  The zinc and silicon in the castings greatly improves the machinability. I cast the alloy into small ingots before making my own casting.
                                             David
