Author Topic: Where to get an LCD tachometer?  (Read 19678 times)
Offline loply
« on: October 02, 2012, 05:48:34 PM »
Hi folks,
Does anybody know where I can pick up a simple, pre-made LCD photo-interrupter tachometer?
I've seen them once or twice over the years but can't find them available now.
I want to hook one up to my lathe as it's hard to know the spindle speed now that I have a VFD. I have a laser tacho but want to wire up a permanent solution.
Cheers,
Rich
Offline Bluechips
Re: Where to get an LCD tachometer?
« Reply #1 on: October 02, 2012, 09:45:13 PM »
I don't know if these are any good, but I have considered getting one for my 16" SB that I put a VFD on. The SFM option looks interesting.
http://mkctools.com/tachoptions.htm
BTW  - I don't know this guy, just stumbled across his products on  the web.
Mike
Offline rleete
« Reply #2 on: October 02, 2012, 09:55:34 PM »
Offline sshire
    • LS Editions
« Reply #3 on: October 03, 2012, 08:16:13 AM »
When I added a VFD to my lathe, I got the Tachulator. Works perfectly. I wrapped the sensing pattern around the spindle inside the gearbox. Especially like the SFM function. The circuit board seems well designed and made. No problems at all.
Best
Stan
Best,
Stan
Offline AR1911
« Reply #4 on: October 03, 2012, 02:59:11 PM »
They are all over ebay for under $20 shipped.
Ive had one for a year, just started using it. it's a lifesaver
Offline loply
« Reply #5 on: October 03, 2012, 06:13:58 PM »
AR1911, which kind did you get? I've tried searching but I can only find laser tachos and automotive tachos, neither of which is ideal.
Offline AR1911
« Reply #6 on: October 03, 2012, 06:17:41 PM »
Loply,  I did not understand you wanted a non-laser variety.
The only one like that I have was originally sold as a fan-clutch tester, and it's pretty crude.
Offline Chazz
« Reply #7 on: October 04, 2012, 12:36:03 AM »
Check out SenDEC tachometers, they have 2 flavors to choose from, RPM only (6,000 iirc) or, RPM while the machine is running & accumulated hours (9,999.9) when the machine is off.
As an example, here is one distributor,
https://www.gdimeters.com/products/5/Products+by+Type/rotating-shaft-tachometer-hour-meter
HTH,
Chazz
Offline WillieL
  • This space for rent.
« Reply #8 on: October 05, 2012, 08:54:54 AM »
Another vote for the "Tachulator". Works flawlessly and very accurate in my experience.
http://madmodder.net/index.php/topic,6766.0.html
WillieL
Midwestern USA
Offline AR1911
« Reply #9 on: October 05, 2012, 09:08:45 AM »
I have a Tachulator that i have yet to install. Bought it directly from the source, a nice guy in Hurst TX, a few miles from me.
But I confess I like the looks of that SenDec better. I may have to buy one and take a look.
« Reply #10 on: October 08, 2012, 03:05:37 PM »
Some VFDs  can measure pulses on a spare input and display the result in RPM.
I have a variable reluctance sensor on the spindle of my mill with a simple op-amp to generate square pulses. The pulses feed one of the ABB VFDs inputs. It requires a half dozen settings to get it to display spindle RPM
