Author Topic: Removing chrome plate from brass  (Read 13109 times)
« on: September 13, 2012, 02:40:21 AM »
Hi,
     I have a quantity of brass fittings which are chrome plated, any suggestions on removal of the chrome and nickel.
     Reverse electrolysis is in my mind, may be using a 12 volt battery charger and a suitable electrolyte. The items would be     eventually recycled into new castings.
Re: Removing chrome plate from brass
« Reply #1 on: September 13, 2012, 03:42:09 AM »
I have heard that hydrochloric acid (muriatic acid) will remove chrome and any base layer of copper. I don't know what strength is needed, though. In the UK, it is sold (low stength) as brick cleaner for removing mortar smears.
If it eats chrome and copper, it will no doubt eat into the brass as well, but I don't suppose you will mind losing a bit if it is for castings.
An idea which might work: simply put the chromed items in your crucible and heat it up. Brass melts at around 900-950C. Chromium melts at 1857C, and is slightly denser than brass, so would remain solid and sink to the bottom, with a bit of assistance to flatten it down. Then pour off the brass.
« Reply #2 on: September 14, 2012, 04:01:53 AM »
Hi Andy
Thanks  for the info. must give it a try.
