Author Topic: another tool for the box  (Read 14370 times)
Offline Pete49
« on: August 28, 2012, 08:52:46 AM »
Today I was doing some work and needed to drill a piece of round rod and thought I should make it easier so decided to make a v-block and clamp. Took most of the day but hey its another tool for the box  . I used a small piece of cast iron I had and heres the result. crappy pic (phone) but works like a charm. Just need to get a shorter bolt.
Offline wd
Re: another tool for the box
« Reply #1 on: August 29, 2012, 07:35:50 PM »
Hi Pete
Would luv to see your images but they're only 96 pixels.Usually 640x480 or 800x600 is ideal.Perhaps resize
Hell, there are no rules here - we're trying to accomplish something.Thomas A. Edison
I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
Offline Pete49
« Reply #2 on: August 29, 2012, 10:59:28 PM »
yeh good idea I'll use the camera this time
Offline Pete49
« Reply #3 on: August 31, 2012, 12:33:00 AM »
OK heres a better pic of the v block  :ddb: The little blow holes will be filled with JB weld.............once I find it :doh:
