Author Topic: not another ball turner question  (Read 9972 times)
Offline daz
« on: August 27, 2012, 04:38:28 AM »
Going to get round to making one shortly, I hope!
Any thoughts on the easiest design to make? It needs to fit on a small clarke lathe and needs to be as simple as possible.
Any ideas guys?
thanks
daz
Re: not another ball turner question
« Reply #1 on: August 27, 2012, 04:52:12 AM »
Any ideas guys?
thanks
daz
Daz
There are many many answers to your question. Here are probably several hundred ideas. type "How to make a ball turner?" into the Google search box and click on the magnifying glass. You will now have links to more ideas than you have time to read.
« Reply #2 on: August 27, 2012, 05:03:10 AM »
Daz, here's a relatively simple one fitted to a Clarke minilathe: http://mikesworkshop.weebly.com/ball-turner.html .
It uses the swivel disc in the cross-slide for its pivot, though if yours is a minilathe, it would be wise to check that the cross slide will go back far enough to get the pivot axis below the lathe centre-line. As you will see, the tool is angled so it can get further round the back of the ball than most variants of Steve Bedair's design can manage.
Offline daz
« Reply #3 on: August 27, 2012, 05:55:04 AM »
My initial problem was typing it into google Don, there are just so many designs and I didn't know which one would be the simplest to make.
The one in the link looks just the job!
Thanks guys
daz
« Reply #4 on: August 27, 2012, 06:08:06 AM »
Daz
I used to always just ask a question on the forums and get an answer and a few people directeing me to Google. At first I was scared of Google and didn't know what or how to do a search. Finally I just typed in "How do I make a kite?" (or whatever I was up to that day) ended it with a question mark and put quotation marks around it. I then clicked the magnifying glass and I had my choice of answers to choose from. Any question that you can ask in a forum can be asked to Google. Best thing is to try asking a bunch of different questions and seeing the responses. It will give you some idea on how to word your questions for a search. Good luck with your ball turner.
Offline 75Plus
« Reply #5 on: August 27, 2012, 09:23:07 PM »
Daz,
This one may not be the one you want to build but maybe you can get some ideas from it.
http://madmodder.net/index.php/topic,2938.msg31621.html#msg31621
Jope
