Author Topic: PW Coat Oven 4x4x4  (Read 15444 times)
Offline Malletheadz
PW Coat Oven 4x4x4
« on: August 18, 2012, 09:42:19 AM »
Any one have any plans for build 4X4 x4? I could use plans, diagrams and electrical diagrams as well as a parts list. I am a newby at this so anything would help .
Thanks, Malletheadz
Re: PW Coat Oven 4x4x4
« Reply #1 on: August 18, 2012, 09:45:57 AM »
Powder Coat oven? I saw some plans somewhere... let me see if I can find them again...
« Reply #2 on: August 18, 2012, 09:50:46 AM »
LINK
He has some plans, construction etc...
Offline PTsideshow
« Reply #3 on: August 18, 2012, 10:51:00 AM »
Here is another smaller one http://www.green-trust.org/junkyardprojects/FreeHomeWorkshopPlans/CuringOven.pdf
This on shows a conversion of a household electric stove.
Yahoo had a powder coating forum. it was run by the guy that wrote the book on powder coating. Which a review is located in our book shelf. Great book by the way.
Instead of the sheet metal shell if you are only doing a couple of large pieces like a bike frame etc.  people use the oven heating elements form the used stoves since, most times the ovens and heating elements aren't used like in the old days. They modify the oven box like here http://web.archive.org/web/20020214081002/www.buckeyetriumphs.org/technical/PowderCoating/powder_coating_equipment.htm or they remove the controls and elements and mount them in boxes made out of the aluminized expanded hard foam insulation board. You can have a large of oven as your electric can handle. They used 1x2" furring strips to hold the insul board together. And always be safe and don't leave the oven unsupervised during operation. I had a link but it is no longer active. But if you go to Eastwoods Powder coating forum.
 :thumbup:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
« Reply #4 on: August 18, 2012, 12:19:45 PM »
I think Caswells plating has a whole forum dedicated to oven building...
Offline snub
  • Canada
« Reply #5 on: August 26, 2012, 01:00:14 PM »
Yes, they do. Lots of good info there:
http://forum.caswellplating.com/oven-building-forum/
