Author Topic: Finely grained dremel drums  (Read 8192 times)
Offline mzt
« on: July 25, 2012, 05:39:24 AM »
I recently read a question somewhere in the e-world about eventual sellers of finely grained dremel drums. Cannot recall (or find) where,
neither say a word about sellers, but they can be made in minutes.
Wrap a full turn (or more) of double sided adhesive tape on a small dia. rod of suitable length. (and suitable dia., too! Don't ask why I know that).
Cut a strip of the desired grit sandpaper as large as the tape is.
Wrap the strip of sandpaper on it, cut it so You will have about 5mm overlap. Take care to wrap it accordingly with the supposed rotating direction.
Put a drop of glue on the overlap backside, wrap the whole into a strip of plain paper and keep it closed with some adhesive tape.
Let it cure for a while.
Make a few, while You're at it: they're not of the quick-replace type.
http://i1226.photobucket.com/albums/ee403/mzetati/_steamEngines/WIP01-Bernay/36/53_IMG_0939.jpgFinely grained dremel drums
http://i1226.photobucket.com/albums/ee403/mzetati/_steamEngines/WIP01-Bernay/36/55_IMG_0954.jpgFinely grained dremel drums
Marcello
Offline picclock
Re: Finely grained dremel drums
« Reply #1 on: July 25, 2012, 07:02:14 AM »
That's an interesting technique. especially for making the small ones. I normally order different grades from
http://richontools.com/index.php?main_page=index&cPath=65
when I order my endmills. Also very good for diamond paste.
I've never seen the other fine grades available in the UK. (No affiliation etc. just a customer).
Best Regards
picclock
