Author Topic: Bending jig  (Read 17779 times)
Offline ksor
    • Keld's hjemmeside
Bending jig
« on: July 17, 2012, 01:50:03 PM »
I needed a bending jig for the handle to the arbors for my furture hydraulic press.
This is what I got  :D
http://kelds.weebly.com/bukkevaeligrktoslashj.html
Best regards
KSor, Denmark
Skype name: keldsor
Offline ksor
    • Keld's hjemmeside
Re: Bending jig - Version 2.0
« Reply #1 on: July 22, 2012, 08:00:20 AM »
Version 2.0 has justbeen released - http://kelds.weebly.com/bukkevaeligrktoslashj.html
Let Google do the translation for you !
Best regards
KSor, Denmark
Skype name: keldsor
Offline ksor
    • Keld's hjemmeside
Re: Bending jig
« Reply #2 on: July 25, 2012, 09:27:07 AM »
Now I should have inserted a combobox for you to select what language you wnat to translate to !  :)
I hope it works as supposed to or else ....  :bang:
Best regards
KSor, Denmark
Skype name: keldsor
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
Re: Bending jig
« Reply #3 on: July 25, 2012, 11:36:37 AM »
It work's wonderfully, Thank you very much  :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow:
Tim
Re: Bending jig
« Reply #4 on: July 25, 2012, 12:21:35 PM »
ksor - could this be used to bend small metal strips into circles of various diameters? Or any thoughts how it could be adapted to do that??
Offline ksor
    • Keld's hjemmeside
Re: Bending jig
« Reply #5 on: July 25, 2012, 12:38:51 PM »
I beleave so - but it wasn't my first priority - I think it can go down to radius that 10-15mm.
If you have to make SOME of the same radius, and then SOME of another radius ... then DON'T make them strips but make then long wire to circles as a spring and saw the turns apart with a thin saw blade - my wife and daughter do that when making silver rings for all their bracelet and stuff like that - they turn the spring with an old  hand driven drill and this way they make 1000's of rings.
If it's not silver but some harder material then you can turn the spring in the lathe at low speed and if it's thick material you can make the spring by heating up and bending the rod around a water pipe or so.
I don't think you need "my" kind of bending jig to make rings - only if you allready HAVE cut the material into peaces  :bang:
Even if I only needed 2-3 or 5 rings I would make them as a spring and then cut it into circular peaces.
Best regards
KSor, Denmark
Skype name: keldsor
Offline ksor
    • Keld's hjemmeside
Re: Bending jig
« Reply #6 on: July 28, 2012, 03:23:35 AM »
>> creynerd
Here are a 3-phase technic for making rings where you HAVE cut strips in the right length
See the attached picture.
Best regards
KSor, Denmark
Skype name: keldsor
