Author Topic: Novice question on ballnuts  (Read 9545 times)
Offline 9fingers
    • Info on Induction motors (Heavily UK based!)
« on: July 16, 2012, 09:47:43 AM »
Looking at typical data sheets for 20mm ballnuts, backlash is quoted as 0.05mm (2 thou). Ok fair enough.
The same manufacturer has double ballnuts that are also quoting 0.05mm backlash.
In my novice eyes, I'd expect use of a double ballnut to be able to achieve zero backlash.
So are double ballnuts adjustable when fitting to a machine to get near to zero?
Apologies if this is a daft question but I don't understand - please be gentle :lol:
Bob
Offline pete3000
  • Electronics, Computers and one day mechanics
Re: Novice question on ballnuts
« Reply #1 on: July 16, 2012, 11:42:22 AM »
Depends on the class of ballnut and the screw used, C7 is a general grade with some backlash. or spend more on C5 grade with preloaded/slightly oversize ball bearings fitted. Double C7 ballnuts will generally have less play than single but you have to ask yourself do you need absolute zero backlash ? and how deep is your wallet?. :bugeye:
The beauty of Not Planning, is that failure comes as a Complete Suprise and is Not preceded by a period of worry and depression.
« Reply #2 on: July 16, 2012, 12:48:29 PM »
Depends on the design of the double nut some are adjustable and some are just advertising hype.
If you want zero backlash then best to use two single niuts back to back and shim them.
However most C7's are better that the absolute resolution of the machine. If they follow spec quoted backlash should be max allowed and is usually better.
Depends on supplier.
John S.
Offline 9fingers
« Reply #3 on: July 16, 2012, 01:57:54 PM »
Thanks Gents
That indeed helps.
As for wallet depth, it is deep enough for me not to want to buy twice but not so deep to automatically opt for the dearest version of everything.
Of course the sensible thing would be to sell my manual milling machine and buy a CNC one but that would be no fun!
Bob
