Author Topic: Furnace rebuild  (Read 12153 times)
Offline Jonfb64
Furnace rebuild
« on: June 25, 2012, 10:23:02 AM »
Hi all,
Started the rebuild of my aluminium furnace about 2 weeks ago. In its old form it had been running for about 5 years on a home made  rectory of fire cement and perlite. I recon about 200 melts of a scrap to ingots and various pours for my Gingery lathe and Shaper.
As  :worthless: here are a few to get going
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/081-1.jpgFurnace rebuild
original before strip
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/082.jpgFurnace rebuild
side view
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/085.jpgFurnace rebuild
lining removed
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/086.jpgFurnace rebuild
lid which will retain the old home brew
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/084.jpgFurnace rebuild
and the old lining which is remarkably solid, was just the hot face that was burning away
As can be seen the outside never got hot enough to burn the paint off. Just hope the commercial refractory (1700c) works as well.
More pics of the lining process to follow.
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/087.jpgFurnace rebuild
this is a shot of the original spill hole
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/088.jpgFurnace rebuild
chain drilling for the new base
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/089.jpgFurnace rebuild
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/090.jpgFurnace rebuild
and chopped out with a chisel
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/091.jpgFurnace rebuild
support ring for new replaceable (cheap) base tacked in place
« Last Edit: June 26, 2012, 12:02:29 AM by JonIndigoman »
Offline Jonfb64
Re: Furnace rebuild
« Reply #1 on: June 26, 2012, 02:28:49 AM »
More pictures
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/092.jpgFurnace rebuild
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/093.jpgFurnace rebuild
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/094.jpgFurnace rebuild
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/095.jpgFurnace rebuild
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/096.jpgFurnace rebuild
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/143.jpgFurnace rebuild
http://i1073.photobucket.com/albums/w397/JonIndigoman/furnace/144.jpgFurnace rebuild
next part of the build and the final shot with lining in place.
the refractory was made with commercial 1700c refractory with added vermiculite in the ratio of 1:1 to make it go further due to the cost, except i ran out with 3inches of the top to fill so used perlite :Doh:
