Author Topic: Clamp hangers in the shop  (Read 6327 times)
Offline PTsideshow
« on: May 11, 2012, 08:28:31 AM »
After I stopped manufacturing cage bird play toys, I decided to change over the basement to other of the shop hobbies. One of which is wood turning /pen making. In using The hard surface counter material and gluing up other material to turn pen bodies.  You use a lot of the 6" spring clamps, I tried a number of things.
And then when I took down some dowels that were used to hold spools of plastic chains. I had an idea, with a short spacer over the screw I screwed them into the bottom of the floor joists. Enough distance from the bottom of the joist to slip over the clamp.
http://i35.photobucket.com/albums/d200/ptsideshow/Wood%20turning/DSCF0004-2.jpgClamp hangers in the shop
Here they are in place.
http://i35.photobucket.com/albums/d200/ptsideshow/Wood%20turning/DSCF0006-1.jpgClamp hangers in the shop
here is a close up of the spacer, the screw in the dowel at the end was to fix a split in the end.
It keeps the clamps handy, and yet out of the way and stored neatly. It is located overhead of the bench where I do glue ups! :thumbup:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
