Author Topic: Now what do I do with all these??  (Read 10402 times)
« on: February 01, 2009, 01:04:04 PM »
Ok, so you may have seen the thread on old lamps, well in the box that they came with there were all of these.....
Some of which I have no idea about a use for. So,my question to the collective.....  What would/could you do with these?   :borg:
First the nice big relay thingy.... AKA table lamp!
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02850.jpgNow what do I do with all these??
Then a big 25V relay/solenoid thingy
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02847.jpgNow what do I do with all these??
A big stop start switch thingy
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02846.jpgNow what do I do with all these??
An old board with loads of relays, some large capacitors and resistors
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02849.jpgNow what do I do with all these??
A big "pull for off" emergency switch
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02854.jpgNow what do I do with all these??
Another big old relay
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02848.jpgNow what do I do with all these??
some very fine copper (I think) gauze
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02856.jpgNow what do I do with all these??
some catch thingys that do still work
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02857.jpgNow what do I do with all these??
some kiln bricks (soldering hearth me thinks?)
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02859.jpgNow what do I do with all these??
And for darren, the picture off the side of the big transformers, they have GU14 on the bottom edge too... I don't know if these work?
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02844.jpgNow what do I do with all these??
http://i289.photobucket.com/albums/ll221/dividedhead/Random%20stuff/DSC02845.jpgNow what do I do with all these??
Well that's it!  They are all in dry storage at the mo'
I wil probably strip most of it for the little bits?  But if anyone has any better ideas.....  :scratch:
Offline John-Som
    • Start Model Engineering
Re: Now what do I do with all these??
« Reply #1 on: February 01, 2009, 03:43:48 PM »
Hi Ralph
Not sure about those electrical thingies. Saw something along those lines last time I watched a Frankenstein movie. Those kiln bricks look interesting though (well fairly interesting !). I made a little hearth for my silver soldering exploits a while back and discovered there are two types of bricks. Those that absorb heat (you don't want those) and those that reflect heat (you do want those).  Have you figured out which yours are ?
John S
start-model-engineering.co.uk - a friendly place for model engineering beginners
« Reply #2 on: February 01, 2009, 04:04:07 PM »
The Glass things strip the middle out, turn them over, fill with water and keep goldfish.  :ddb: :ddb: :ddb:
The rest put on ebay ther's bound to be someone who knows what they are and will wont them. :  :lol: :lol:
Cheers :wave:
« Reply #3 on: February 01, 2009, 05:15:22 PM »
Those latches look very useful for the shop, fold up tables come to mind.
I will take a little square of mesh off your hands if you can spare it. The mini bunsens I will be making in the future require very fine metal mesh as a tip diffuser.
« Reply #4 on: February 01, 2009, 05:44:54 PM »
Two black transformers are interesting, what pysical size are they Ralph?
They are of course valve power supply transformers and will not be much use for much else.
Why?
Firstly they are designed for 115V mains, so in the UK the primaries of both transformers need to be wired in series.
Output is 700V, further adjusted up or down with the 170, 10, 10, windings as required.
But this will only offer a very low current that suits valve HT requirements.
The three 6V taps are quite powerful as needed for many valve heaters.
Now then, that change over switch solenoid. Perfect for someone with a second mains power source. Flick second power source on and the relay would disconnect from the grid mains supply and connect to the secondary supply.
Nice bit of kit
Darren
« Reply #5 on: February 01, 2009, 09:03:00 PM »
John S,  :wave: Glad to see your still watching  :)  The bricks are of yet undetermined type..... But now I know I'm looking, I'll test and report back  :thumbup:
Stew,  Useful suggestions. Problem 1/ The glass bowl has a hole in it! Problem 2/ you need to know what you have in order to e-blag it succesfully!!  ::)
Bog's,   Mesh is yours, I'll bring you some when I visit next  :thumbup:  Oh, and the latches too if you have a use for them?  :)
Darren,
Well there's a lot to take in and process!!
size, approx 3"square width and depth and 6" tall..... Bloody heavy too!!
What are 6V taps?
The switch over solenoid sounds interesting.... How could I employ it in my day to day activities?.... Does this mean wind turbine?  :scratch:
I can see this will need more discussion.... I may be on a trip to the vallies with a back seat full of stuff !!!??
Gonna do some searching to see what I can find out.....  (more pictures of attractive ladies who know nothing about the subject I'm searching for I suppose!!  :doh: )
« Last Edit: February 01, 2009, 09:13:45 PM by Divided he ad »
« Reply #6 on: February 01, 2009, 09:18:56 PM »
Ooooo I want the pictures of the lovely lasses. Yes?
« Reply #7 on: February 01, 2009, 09:36:25 PM »
Ralph I'll expand if it helps,
(2x115=230, near enough to our 240V mains)
(700 + 170 = 870 + 10 = 880 + 10 = 890 Volts,     or      700 -170 = 530 Volts etc   jumble the connections around to get the voltage you need)
All low current in the order of ma (milli amps)
(a tap is a winding, sort of. If you take one winding and tap it off part way (make a connection) you have a lower voltage of the original winding. Autoformers do this (a type of voltage reducing transformer)
If you can use it then use it, if you can't I prob know someone that can.... :thumbup:
Nice bit of kit
