Author Topic: Index wheels  (Read 11131 times)
Offline Pete49
Index wheels
« on: April 11, 2012, 03:17:06 AM »
I'm making a few missing index wheels for my faceting machine and while I was able to make the 40 & 48 tooth cogs I still need others. Is there software out there that will let me print out cogs the size and tooth count I need so I can stick them to the brass discs to file them out? Easily done with a 3 corner file as there is shape wise is a 'vvvv' shape and the 2 I have made are good to go so I figure I can make the rest if I can find a way to make the paper patterns. Any ideas?
The reason I'm making them is because money not so much (Aussie pension) time I have plenty of. Also I think the machine maker is gone its an old MDR.
Posted on onother site but fishing for ideas so the more chance of a method to use :thumbup:
Offline David Jupp
  • Teesside - UK
Re: Index wheels
« Reply #1 on: April 11, 2012, 03:55:09 AM »
Take a look at Gearotic - http://gearotic.com/
There are probably several other options worth considering too, might even be easy with a basic CAD system if you don't need teeth to mesh with other gears.
Re: Index wheels
« Reply #2 on: April 11, 2012, 04:59:41 AM »
You might try :-
http://woodgears.ca/gear_cutting/template.html
It's intended for wood gears, but it would be good for any material and what's more it's free!
Many, many uses possible! (No John it's not L**ux specific!)
Offline Pete49
Re: Index wheels
« Reply #3 on: April 11, 2012, 11:56:49 PM »
Thanks guys its now a done job :beer: well except for the filing
Offline rotorhead
Re: Index wheels
« Reply #4 on: April 15, 2012, 12:44:41 PM »
Hi all,
If anyone needs an involute gear calculator this website has a free one- http://www.quickspline.com/id13.html
Sunny Scunny,
North Lincolnshire.
