Author Topic: Toolholder Mod.......  (Read 24948 times)
« on: April 10, 2012, 08:22:19 AM »
One of those, "why didn't I think of that before", mods.......   :Doh:
I've recently fitted a Dixon type toolpost to my mini lathe, and the tool pockets are a little shallow.
My favourite knife tool has to be canted to the left, to provide clearance. And canted ever more as it is reground, until the tool will no longer locate under the first screw.
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020154.jpgToolholder Mod.......
So, I milled the rear end of the pocket 1/4" deeper, using a10mm carbide, 3 leg endmill.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020156.jpgToolholder Mod.......
Finished, deburred........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020162.jpgToolholder Mod.......
Lots of adjusting room now........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020165.jpgToolholder Mod.......
David D.
Re: Toolholder Mod.......
« Reply #1 on: April 10, 2012, 09:51:58 AM »
 :coffee: Well, you've done it now, Dave, but I think I might have taken the alternative route of tapering the side of the tool shank, unless it was horribly hard.
« Reply #2 on: April 10, 2012, 03:11:01 PM »
Not hard Andy.
But, I thought it better to mod one of the holders, rather than every tool I buy in the future.......  :thumbup:
Offline Anzaniste
« Reply #3 on: April 12, 2012, 03:26:51 AM »
I slacken the tool post hold down bolt and twist until the angle presented by the tool is what I want. Takes seconds.
« Reply #4 on: April 12, 2012, 03:57:23 AM »
Yes..... But.
Having to align at each change, defeats the purpose of QC toolholders.
I like to keep mine aligned square, and locked.
Am I the only one who's had an angled toolpost creep (twist), under cutting forces?  :scratch:
« Reply #5 on: April 12, 2012, 04:04:08 AM »
No, you're not alone  :(
I scraped the underside of mine flat, to increase the contact area and friction.
Andy.
« Reply #6 on: April 12, 2012, 04:09:23 AM »
Ah! Thanks Andy.......  :thumbup:
The present cross slide top surface, base block, and toolpost, will almost wring together.
The original set up, left a lot to be desired.......  :palm:
« Last Edit: April 12, 2012, 07:39:04 AM by Stilldrillin »
« Reply #7 on: April 12, 2012, 08:49:08 PM »
Nice fix David.
Just curious, why would future tools have the problem as well?
« Reply #8 on: April 13, 2012, 01:50:24 AM »
Thanks Eric.
Future knife tools will also need canting to the left, as their cutting edge is gradually sharpened away.......
« Reply #9 on: April 13, 2012, 09:40:32 AM »
Looks like it does the Job David  :thumbup:
The way I see it we all make and mod' stuff to our own specific needs.
If it does what it was intended to do then it's a good mod'  :dremel:
« Reply #10 on: April 13, 2012, 09:56:15 AM »
Thanks Ralph!  :thumbup:
Yer'l do for me........  :D
« Reply #11 on: April 13, 2012, 10:31:37 AM »
Thanks Eric.
Ahh! Ok!
lordedmond
« Reply #12 on: April 21, 2012, 11:20:02 AM »
David
just a heads up regarding those tool posts ( yes I do use the same style ) is that all of the holders that you buy shall we say cheaply ( the proper ones are £40 each ) from rotagrip post is £150
My point is that they are not all made to the same hymn book I have just replaced my tool post due to the old one failing  ( cracks in the wedges ) I have had to scrap a good few of the pattern ones as they would not pull up with the worst  having a 0.75 mm gap no wonder the old post had trouble
so please when you buy some more it worth checking
BTW if you have a tilt head mill they are very easy to make the main slot is cut with a myford tee slot cutter and the Vee's are 48 mm to the points , bung a 12mm ( you do need that size to cut both the Vee faces at one setting ) tilt the mill head to 45 deg and mill away they should be 7.5 mm deep but do check you post 25 mm square stock is OK 58 mm long
Stuart
« Reply #13 on: April 22, 2012, 10:47:13 AM »
Thanks for that Stuart!   :beer:
I had a conversation the other day, with the "quality" supplier, to the effect I had bought from "Ratner's".......  :lol:
For the type of work I do, this quality is quite adequate......
And, frankly, for the years I have left, it's not worth investing the price of a new lathe, in just a toolpost and 6 holders!  :loco:
I have the post and four holder set, and another pair of holders from a different supplier. They all fit together nicely. So far....  :D
But, I will keep a wary eye open for any future problems........    :thumbup:
lordedmond
« Reply #14 on: April 22, 2012, 11:52:35 AM »
yes David
please be aware its very obvious when they don't fit you can see it , otherwise they come loose under the cutting pressure , as I said its mainly the Vee's but the flat back can be too thick
glad yours are OK
Stuart
