Author Topic: Some of the work i do at my real job!  (Read 9200 times)
Offline lazylathe
  • Mastering the art of reducing metal into swarf!
« on: March 21, 2012, 07:29:50 PM »
Hi All,
Thought i would share some pictures of what i do!
Dental technician by trade, 5 years at Technical College and ended up with a B.Tech Degree, many years ago... ;D
Anyway we had a cool case come in that sort of related to machining!
A gold implant bar needed some 1.8mm holes drilled and then tapped with a 2mm tap.
Studs screwed into the bar to which attachments that are in the denture will snap into.
We usually work with Titanium, this was an older implant bar.
The bar and the tap
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0144.jpgSome of the work i do at my real job!
A fuzzy picture of the locator attachment
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0145.jpgSome of the work i do at my real job!
Setting up in the surveyor
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0146.jpgSome of the work i do at my real job!
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0147.jpgSome of the work i do at my real job!
Ready to drill the first hole
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0148.jpgSome of the work i do at my real job!
Applying cutting fluid while drilling
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0150.jpgSome of the work i do at my real job!
Almost there
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0151.jpgSome of the work i do at my real job!
Tapping the holes
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0153.jpgSome of the work i do at my real job!
Fuzzy picture of tapped holes. You can just see some fine threads in the far hole
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0154.jpgSome of the work i do at my real job!
One locator in. You can see the threads better in the far hole this time!
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0155.jpgSome of the work i do at my real job!
Both in tight!
Just needs a good polish now!
http://i926.photobucket.com/albums/ad107/LazyLathe/Implant%20bar/IMG_0156.jpgSome of the work i do at my real job!
Hope someone found this to be of some interest!
Not everyones favourite topic... ;D
Andrew
Re: Some of the work i do at my real job!
« Reply #1 on: March 21, 2012, 07:35:36 PM »
Andrew
So they pay you to play with kit like this :lol: :lol: :lol: :lol: :lol:
« Reply #2 on: March 21, 2012, 07:37:18 PM »
Fascinating! I bet you were careful to collect the swarf  :)
When you say it's an "older implant bar", is it one that's been pulled out of someone's jaw for repairs?
Offline lazylathe
« Reply #3 on: March 21, 2012, 08:36:19 PM »
YES!!! They actually pay me to do this!! :dremel:
All the gold dust and waste gets collected and sent for refining.
The boss gets a HUGE check every 6 months or so....
This bar had different attachments on it that were failing and the company had gone out of business.
We cut them off and replaced them with new modern ones.
Also because the bar is cast out of gold it is very expensive to make these days.
We usually CAD design them and have them milled out of medical grade Titanium.
Cheaper, lighter and so much stronger since it is milled from a solid homogenous block.
The owner will soon be eating steak again! :headbang:
Andrew
