Author Topic: My 6 cylinder boxer  (Read 13609 times)
Offline Feliks
    • www.new4stroke.com
My 6 cylinder boxer
« on: March 10, 2012, 12:45:44 PM »
My 6 cylinder boxer..
Can have two times less cubic capacity, because that is two times smaller turnover at the flywheel.
Regards Andrew  :coffee: :coffee:
Offline Feliks
Re: My 6 cylinder boxer
« Reply #1 on: March 10, 2012, 12:48:35 PM »
And in the meantime since the formation of the ideas, changes a lot. For example, go beyond the "magic circle of the cylinder" was the hardest thing.
 When I discovered  it, a new type of timing, was the new 4 stroke engine:
Three pistons and thousands of possible combinations. Not only the diameters, but also the position of the angle between them are very significant.
Even so, a simple calculation of the geometric sum of displacements, which formerly had to be the diameter of the cylinder times the stroke, in this case the employment needs to calculate its computer...
Complicated science you need to establish, but later are incredibly large benefits.
I am started, learning, doing this in Excel program for calculation of these basic geometric figures. All colored fields can be changed, and entered sa values from my prototype Already in the same calculation shows a very surprising things. no, for example, from the smallest the combustion chamber ,is some degrees for the TDC root of the piston.
(interesting, whether it will have much more power, as has the amount of ignition in the traditional construction. ??)
http://www.new4stroke.com/volume.zip
http://www.new4stroke.com/volume.xls
Some facts about this construction
http://www.new4stroke.com/new4stroke.pdf
It is certain, you need good scientific and applied to this case, but better twice think twice to do. :)
NEW:During exhaust, exhaust gases drive the two "valves" and add torque.
Offline AndreasL
« Reply #2 on: March 12, 2012, 05:39:56 AM »
Wow!
Do you have any figures (power, consumption, etc, etc) from a runing engine?
Love to see and listen to one.
EDIT: Found it at the homepage.
