Author Topic: Set up a retangular block in the 4 jaw chuck  (Read 26015 times)
« on: February 18, 2012, 12:50:08 PM »
The block in question 3.2” x 2.8” x 2” thick.
I have already marked and centre punched where I want to bore/drill a hole or cut a boss.
A word about the centre punch mark. The punch I use is only used for this purpose I do not use it for general centre punching. The reason being it was ground carefully to an included angle of 60 deg. Also the mark is produced by taping a number of times and rotating the punch, all the time keeping it perpendicular to the face. If one is trying to centre the block + or – ½ a thou or so, then the centre punched mark needs to be done with care. Giving it one almighty whack isn’t really the best start!
776
Here are the bits we are going to use.
A MT3 (non rotating) centre, and a “centring” bar. I call it a “centring” bar it’s that long thing at the bottom next to the rule, just to note it is a solid bar it is not sprung loaded.
773
The “centring” bar is about 12” long, 12mm dia. It has a point at one end at an included angle of 60 deg. The other end is centre drilled with a centre drill (again 60 deg)
774
775
This is the set up. The mag clamp in the foreground is to hold the camera.
772
The rectangular block is chucked up – try to get it as close to being central as you can, use the concentric circles on the chuck. Just pinch up in the jaws,  the block needs to move.
The plunger of the dial gauge needs to be as close to the pointed end as possible, this is where the maximum movement is. I had to change the dial gauge to a 1” travel one to accommodate this, otherwise the block would hit the dial gauge.
763
Now we can start to centre the centre punch mark. This is done in exactly the same way as we did for the round bar, see this  http://madmodder.net/index.php?topic=6498.msg68965#msg68965
Starting with jaw # 2 zero the dial gauge using the cross slide.
764
See what dial reading we get for jaw # 4. The needle has moved 40 divisions.
765
So by adjustment of jaws # 2 and 4 the block is moved (back) to give a reading of 20 divisions, half of the 40 divisions moved.
766
Turn the chuck back to jaw # 2 and zero the dial gauge by moving the cross slide.
 770
Now turn the chuck to jaw #4 see what we get. Well you can see it is .001” out. Remember we have not fully tightened the jaws up fully yet. This .001” can be reduced by the final jaw tightening
769
Do the same for jaw # 1 and 3.
During the final tightening do opposite jaws and watch the needle movement on the dial gauge. Here one needs to be careful, gentle, and watchful.
Now one does not always need it to be so accurate and if it is out by a thou or two – that may be fine.
Here the video when all done
You can if you look carefully see the needle does move a touch.
Now you can turn that 2” dia boss or bore a 2” hole.
Some important points to note.
The “centring” bar is the prime bit in all this. It must be straight, and it is easy to check to see how straight it is. When it is all set up zero the dial gauge turn the “centring” bar see how much the needle moves – it should hardly move at all.
This “centring” bar should be a snug fit in the non rotating centre and the centre punch mark, that is to say it will turn but there is no lateral movement. This snug fit needs to be checked often and after each adjustment of the work piece (very important). This is why spring loaded “centring” bars are used.
I use a solid “centring” bar,  two reasons:
1) If you do want to use a spring loaded one it must have no (none) lateral movement.
2) I’m too damn lazy to make one.
Then there is the proverbial question should the “centring” bar be allowed to turn or should it not be allowed to turn.
Well if your “centring” bar isn’t dead straight, then don’t allow it to turn.
If the “centring” bar is dead straight, then you choose.
Offline WillieL
  • This space for rent.
Re: Set up a retangular block in the 4 jaw chuck
« Reply #1 on: February 18, 2012, 03:43:56 PM »
Nicely done David. And your photographs are outstanding!   :clap:
WillieL
Midwestern USA
Offline Chuck in E. TN
  • USAF Retired
« Reply #2 on: February 18, 2012, 03:49:57 PM »
Yes, very nicely done. I guess I can do away with my pump center... Got an old injet printer waiting to donate the bar...
Chuck in E. TN
Chuck in E. TN
« Reply #3 on: February 18, 2012, 03:58:14 PM »
Thank you Willie
Thank you Chuck
Offline Fergus OMore
« Reply #4 on: February 19, 2012, 03:01:59 AM »
Might I also congratulate Dave for his contribution?
Mine is a fairly simple sort of one but I 'spring loaded' mine with an internal spring to save ( I think) getting annoyed having to adjust the tailstock poppet during set up.
It isn't new, mine came from Model Engineers Workshop Manual by George Thomas.
Regarding set the 'spot', I tend to use the one of these lens affairs which have a series of cross hairs and spots, and belt the point with a toffee hammer. Mine was a commercial affair but the design or concept has been published and re-published over the years in Model Engineer etc. I recall 'Geometer' doing a series called Microscope on the Lathe. It still is on the Nemes-s.org site and I wrote about it way back in Homeshop Machinist.
It's all perfectly simply and cheap now because 'foreign' but quite decent binoculars and children's microscopes are available to add to the workshop tools.
I tend to use a a folding eyeglass which was given to me years ago by the author of 'Stephenson's Gear' and 'Walshaerts Gear'. I think Don Ashton has amalagamated his two books now. My other 'tool' is a pair of surgeons operating glasses which I mentioned just recently.
« Reply #5 on: February 19, 2012, 07:09:33 AM »
Thank you Norman.
A good spring loaded centring bar does help - no doubt about it.  :) Keeps it nice and "firm"
As my eyes get more tired the better the magnifying lenses get :)
« Reply #6 on: February 19, 2012, 08:30:08 AM »
Nice to have 'quality suggestions' so well illustrated.
For those who have yet to get dial mikes, the setting gauge is remarkably indicative of getting it right by itself. Again, there is a nice bit of fancy boring- to learn if you go 'madly enthusiastic'
Somewhere, I have a 'tenths' dial mike  but I need a Sherlock Holmes magnifying glass to find it.  :hammer:
Dave, more of the same, please!
« Reply #7 on: February 19, 2012, 06:28:19 PM »
Very well shown & explaned :thumbup:
Pictures are first class :thumbup: :thumbup:
Time for me to get a better camera :doh: :doh:
« Reply #8 on: April 16, 2012, 02:54:12 PM »
Thanks John
Offline crankshafter
« Reply #9 on: April 16, 2012, 04:09:32 PM »
Hi DaveH
Thank you for the nice pics' and wrigthup. :beer: :clap:
Ps: I'v been doing it this way for maaany years, works great every time :ddb:
CS
