Author Topic: a tool dilemer  (Read 12269 times)
a tool dilemer
« on: February 09, 2012, 02:24:43 PM »
HI all i have bin given a Bristol Erickson Colet chuck with sum Colet's see pic its missing its nut where can i get a new nut from  my first thought was to mack this in to a Colet holder for my lathe it wood not be that hard had a look on the net and thees things seem to be rather expensive my Q is shod i sell it and at what price or go a Head and mod it  right pics
Re: a tool dilemer
« Reply #1 on: February 09, 2012, 03:21:00 PM »
First thought that comes to mind is - why not make a new nut?  Isn't that why most of us are here?
-Sparky
Re: a tool dilemer
« Reply #2 on: February 09, 2012, 04:13:09 PM »
O if it was that simple don't have the right gears to set the lathe up to cut the thread needed
Re: a tool dilemer
« Reply #3 on: February 09, 2012, 04:30:11 PM »
Not sure what threads you're looking at, but is there a nut or something else with the same threads that could be modified or repurposed?  Maybe have someone else do just the threads and you finish the rest?  Just trying to think outside the box a bit here...
-Sparky
Offline Swarfing
Re: a tool dilemer
« Reply #4 on: February 09, 2012, 04:52:15 PM »
I had some INT30 collet chucks with mill when i got it (changed all to R8). The nut was not anything special, i would try and get a normal nut and weld a plate over the end, there was a small radius in the bottom of the nut if i remember right? but you could turn the front of the nut out and turn a plate with the radius so it drops in?
Just an idea
Once in hole stop digging.
Offline DaveH
  • Kempton Park, South Africa
Re: a tool dilemer
« Reply #5 on: February 09, 2012, 04:55:52 PM »
Hi Bob,
No dilemma, sell it and buy something else  :) :) :)
Offline 75Plus
Re: a tool dilemer
« Reply #6 on: February 09, 2012, 06:07:45 PM »
It appears that the nuts are available at least on this side of the pond. Not sure this is the correct size but if this size is available other sizes should be also. They don't want an arm and leg for them either.
http://www1.mscdirect.com/cgi/NNSRIT2?PMAKA=71345649&PMPXNO=16840712&cm_re=ItemDetail-_-ResultListing-_-SearchResults
Offline Swarfing
Re: a tool dilemer
« Reply #7 on: February 09, 2012, 06:37:00 PM »
Offline Swarfing
Re: a tool dilemer
« Reply #8 on: February 09, 2012, 06:38:39 PM »
Ignore that wrong nuts they are for ER's, just too quick with the cut and paste
Re: a tool dilemer
« Reply #9 on: February 10, 2012, 06:08:00 PM »
HI no problem thanks all with the help this thing looks like new so i ant gowning to mod it just clean it all up and put it on her for sale
