Author Topic: a great project for all us that haul old heavy stuff home.  (Read 21910 times)
Offline PTsideshow
« on: January 22, 2009, 06:26:38 AM »
It was asked on a welding forum for ideas for a receiver mounted lift crane.  I have been thinking about making one. The following link for a commercial one made from aluminum is nice but don't need anything that pricey for occasional use.
But it did give me an idea about using a trailer tongue jack for the leg support and the type of jib crane HF sells.
http://www.spitzlift.net/products/truck.htm
If you look through the photos and info on the site you will get the idea.
The only other idea was using a pipe bender mounted to a receiver plate and on the truck. Problem is it's limited use as it can't put the load into the bed. And being in line with the hitch it limits the size object to less than half the bed width. He was lifting cement chunks out of his garage floor for a flush mount cycle lift! Seemed a lot of extra work as he had a cement saw. He could have cut the slab into two smaller sections and then moved them, instead of sidewalk sized sections. But what the hey!  :doh:
« Last Edit: January 22, 2009, 06:35:21 AM by PTsideshow »
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Re: a great project for all us that haul old heavy stuff home.
« Reply #1 on: January 22, 2009, 10:05:28 AM »
Hey PT,
Great find. I could use something like that to lift wooden pallets into the back of my pickup. The 4 X 4's are a bit higher and lifting an oak pallet up that high just about does me in with my condition.
This can wipped up in a weekend. Will have to look into for a summer project.
Offline PTsideshow
« Reply #2 on: January 22, 2009, 11:04:02 AM »
I'm thinking of making the outrigger leg, that holds the crane have a hinge pin at a point were it comes out of the receiver.
Sort of have two half circles of plate with say at least 3 holes for a hitch pin in it to lock it in place.
And use the trailer tongue jack leg with a metal wheel on it and another brace at the hitch area.
That way you can load from either side or with the crane in the middle. With the cranes that pivot you could have real world movement to the arm that you could reach out from the side of the back of the bed to lengthen your reach so to speak!
As you have said it is a summer project here to along with hooking up the furnace in the shop and 100 others items  :coffee:
But it is some thing to think about. Just looked at the last Horrible Fright flyer they have a couple of the battery electric winches.  Which would eliminate the hard cranking. Just have to make sure it has an control lowering function rather than free wheeling cable play out.  :bugeye: or else look out feet! :jaw:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
« Reply #3 on: January 22, 2009, 12:24:45 PM »
I like that wheel idea. Probably only work on pavement though, unless you use a large wheel. :thumbup:
I threw that last HF catalog away so will have to wait for the next one. :bang:
I've also been toying with idea of putting a crane on my trailer that can be put on and taken off. I could use my tractor with the bucket to put on/take off the crane. So it could be quite a heavy build. :coffee:
Offline rleete
« Reply #4 on: January 22, 2009, 01:09:53 PM »
Oh, yeah Bernd.  You really need another project to start.  How about two more, just to keep it even?   :D
Get back to work on the coke bottle!
Sheesh, you sound like me.
« Reply #5 on: January 22, 2009, 03:57:11 PM »
Well, you need winter projects and then you need summer projects. :D
I have a couple of summer projects lined up so I just want to add one more.  :)
Ok, back to the coke bottle engine it is.  :thumbup:  :headbang:
Offline rleete
« Reply #6 on: January 22, 2009, 04:11:37 PM »
Excerpts from a fake Wiki page that my friends made at the forum where I moderate:
rleete is well known for starting a project every 43 minutes. Unfortunately for those around him, he only completes a project every 3 millenia. Experts predict that by 2012, all of Rochester, New York will be buried in a 35 foot thick pile of refuse originating at the Leete household.  Is often heard to utter, "anyone wanna help me build a ...?"
Most Likely Cause of Death: Self-inflicted wounds stemming from a combination of astonishment at actually finishing a project, and twelve square feet of 60 grit sandpaper.
« Reply #7 on: January 22, 2009, 05:50:21 PM »
My turn. How about some pictures of your finished engine?  :poke:  :poke:  :poke:  :lol:
So that's what that pile is when I look into Rochester.  :scratch:  :lol:  :lol:  :lol:
Offline rleete
« Reply #8 on: January 22, 2009, 06:46:06 PM »
What finished engine?
Okay, I'll post some pics.  Look for a new thread, coming soon.  Maybe I'll just assemble it, and finish the polish later.
I can't get the paint on the base to come out decent.  It's PVC, so I'm using a plastic paint (which I believe is enamel), and it just isn't turning out well.  Sanding is a pain, because it easily gums up the sandpaper.  I just about had it where I wanted, and when I turned the can upside down to clear the nozzle, I blasted a bunch of dust onto the surface.  Doh!
Offline PTsideshow
« Reply #9 on: January 23, 2009, 07:04:18 AM »
Here is the link for the pipebender type limited usefulness
http://www.hobartwelders.com/weldtalk/showpost.php?p=346288&postcount=4
Here is another along the lines of what I was talking about.
http://www.millerwelds.com/interests/projects/ideagallery/project/2780811473/
 :coffee:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
« Reply #10 on: January 23, 2009, 09:08:53 AM »
PT,
The pipe bender one qould fit nicely on a garden tractor. I see that guy plays with Porshe's too. :bugeye:
The one from Miller seems to be a pretty hefty lifter. I see that the tailgate of the truck must of had more than one tree stump set on it from the looks of the bow in it. :)
Great idea givers there. :thumbup:
