Author Topic: compact 8 thread cuting gage  (Read 8583 times)
« on: January 21, 2012, 06:25:14 PM »
HI can any one help I'm after pics dimensions drawings of the thread pitch gage that bolts on to the Cross slide
Re: compact 8 thread cuting gage
« Reply #1 on: January 21, 2012, 08:16:08 PM »
The only pic I've ever seen is this one: http://www.blueridgeshoponline.com/product.sc;jsessionid=1FA299E532AD70FF1991357C3BED393C.qscstrfrnt03?productId=639&categoryId=29
I found a thread dial indicator (TDI) dead easy to make:
http://andysmachines.weebly.com/roll-your-own-threading-dial.html
But if your leadscrew is metric, you will need more than one pinion to engage with the leadscrew if you want it to cover the full range of metric threads from 0.25 up to (say) 3mm pitch. However, if the metric pitch you want to cut will divide exactly into the pitch of your metric leadscrew, you don't need a TDI at all; the half nuts can be engaged ad lib. For example, if your leadscrew is 2mm pitch, you can cut 0.25, 0.4, 0.5, 1.0 and 2mm pitches with gay abandon, because they all divide exactly into 2mm. A 3mm leadscrew adds 0.75 (a metric fine pitch) and 1.5mm to that list, but then you can't do 0.4 or 2mm easily, because they don't divide exactly into 3mm. You can of course do them if you keep the half nuts engaged throughout
Remember that you can never use a TDI when cutting imperial threads with a metric leadscrew or vice versa.
« Last Edit: January 22, 2012, 09:06:15 AM by andyf »
« Reply #2 on: January 22, 2012, 04:28:10 PM »
HI andy jus what i was looking for thank
