Author Topic: My lathe is dead  (Read 38940 times)
Offline John Swift
Re: My lathe is dead
« Reply #25 on: November 27, 2011, 12:12:44 PM »
Hi Benni ,
Yes the photo confirms what I expected
with out a picture of the printed circuitside
I Can't see exactly how the ribbon cables are connected
but it looks like its a simplified version of the CJ0618 relay board and a basic 5v supply for the tacho
what i can't see in the photo is the neutral wire to the board
the two green wires will be to R4 (4K7) used to reduce the speed in reverse
the two red wire I expect to be the live mains supply to the board and the switched live to the speed control board
with the picture of the other side I will be able to tell which is live in and which is live out
the black and brown wires are the controlled DC supply
It looks like the relay is a three pole relay
once the circuit is traced
we can plan how to test each board on its own
Offline pete3000
  • Electronics, Computers and one day mechanics
« Reply #26 on: November 27, 2011, 05:56:32 PM »
looks like the red L1 is the live, and not cleverly the red L2 is the neutral supply coming from the solder splash board. The red L2 neutral is T'd off on a spade. Both should be removable to isolate the mains to the relay board. If the diagram is correct.
The beauty of Not Planning, is that failure comes as a Complete Suprise and is Not preceded by a period of worry and depression.
Offline minerva
  • R.A.F. (retired)
« Reply #27 on: November 27, 2011, 06:21:29 PM »
Hi Benni,
I have just chanced upon your problem , You have my sympathy for  I experienced quite recently similar problems which prompted me to examine in detail the electrics of my lathe (the same model as yours) having got the machine working again I documented the said exercise on my web-site. where I have gone through the regimen employed in trouble shooting the machine.
During the process errors in the meagre documentation came to light and the circuit diagram duly updated. if interested details may be found here:
www.minervasmiscellany.com
Hope this may be of some use to anyone  experiencing electrical problems
regards
terry   T
AKA Minerva
« Reply #28 on: November 28, 2011, 07:23:40 AM »
Terry,
Welcome to the group and nice write up there  :thumbup:
As an aside, the comments apply equally to the minimill series as well, the elctrics are very similar if not the same....
« Reply #29 on: November 28, 2011, 11:39:48 AM »
I have just talked to my supplies and I have order a new lathe, the old one is for my sun in law to try to fix.  :smart:
I will say thanks to al of you, trying to help me, but I feel that this is the best way. :headbang:
Offline minerva
  • R.A.F. (retired)
« Reply #30 on: November 30, 2011, 05:47:51 PM »
thanks for the comment, as you no doubt noticed my mill is also of the Real Bull stable and one of the main reasons for my choice was that of commonality with regard to the electrics, although touch wood so far all is well. (there I've said it) I hope it stays that way. I have just upgraded my lathe  to a Chester 920 which is a machine of somewhat greater capacity but is belt driven with a gearbox which facilitates screw cutting so I'm hoping electrical problems will be a thing of the past. I'm currently making a QCTP  and so far am well pleased with the results.
Regards to all,
TerryT
« Reply #31 on: December 21, 2011, 03:40:47 PM »
Hi all, here is a happy news from me, my new lathe has arrive.  :D
I shell only do some adjustment, as a new lathe always require, and then I will contion to build.  :med:
« Reply #32 on: December 22, 2011, 03:25:39 AM »
Benni,
That is good news...Just in time for Christmas too.......
« Reply #33 on: December 22, 2011, 03:40:18 AM »
Nice one Benni  :ddb: :ddb: :ddb: :ddb:
What you going to build next ?
« Reply #34 on: December 22, 2011, 03:56:37 AM »
Well done Beni happy new lathe,
What you going to make ?.
« Reply #35 on: December 22, 2011, 04:29:04 AM »
Rob Wilson Well first I will finish doing the reversing gear to my D10, then I am thinking about Stuart Compound.  :smart:
Thanks all and I wish a Merry Christmas and Happy New Year to all of you.  :wave:
« Last Edit: December 22, 2011, 03:14:08 PM by Rob.Wilson »
« Reply #36 on: December 22, 2011, 04:40:29 AM »
« Last Edit: December 22, 2011, 02:50:42 PM by Rob.Wilson »
« Reply #37 on: December 22, 2011, 06:52:13 AM »
Thats right Rob, I take the bull by the horns.  :)
Offline arnoldb
  • Windhoek, Namibia
« Reply #38 on: December 22, 2011, 11:57:37 AM »
 :thumbup: Good to hear you have a lathe again Benni  :D
That's a nice engine you want to build as well  :thumbup:
 :beer:, Arnold
« Reply #39 on: December 22, 2011, 02:54:15 PM »
Nice looking engine  Benni ,,,,,,,,,  :thumbup:  ,,,,, looks like it will keep you out of trouble for a wile  :dremel:
« Reply #40 on: December 22, 2011, 04:32:39 PM »
Trouble what's that, can I eat it?  :lol: :lol:
