Author Topic: jonesies popcorn designed by stew  (Read 14785 times)
Offline jonesie
« on: November 12, 2011, 03:21:17 PM »
here is the start of my popcorn engine designed  by stew. also thanks to brian for mock up. the flywheel l i think  turned  out real good. took some time to bend spokes . need to  put radius on cylinder and crosshead. tough stuff done so now should go fast
Re: jonesies popcorn designed by stew
« Reply #1 on: November 12, 2011, 03:39:12 PM »
looking good  :thumbup:
Did you silver solder the fly wheel ?
I particularly like the look of it, spokes look to be more of a curve than mine.
« Reply #2 on: November 12, 2011, 04:35:42 PM »
jonesie, it's looking fantastic good, but I have to ask you please don't load up picture that size, it's very hard to have a good look.  :Doh:
« Reply #3 on: November 12, 2011, 05:04:00 PM »
Looking very good
I like the shape of the flywheel :thumbup: :thumbup:
Offline jonesie
« Reply #4 on: November 12, 2011, 11:37:05 PM »
stew i silver soldered the spokes in the center hub, them turned the o.d. to a light  press and used 620 locktite into the bore.had to make the spokes twice as i had trouble getting them to solder, opened the holes up .003 and then pickled it all for a couple of days in vinegar . then used a larger tip to get the right heat, second time a charm. hope to get more done this week, need to cut the radius on the two parts.i also need to get some fire brick to help in silver soldering.jonesie
« Reply #5 on: November 13, 2011, 02:14:04 AM »
Jonesie
You can use thermalite blocks they are a lot cheaper than fire bricks, and you can cut them to shape with a saw.
Offline jonesie
« Reply #6 on: November 13, 2011, 09:01:06 AM »
thanks for the advice stew, i will have to look up a supplier over here.just need that little extra to help with the heat. jonesie
« Reply #7 on: November 13, 2011, 12:41:14 PM »
You can get the termalite from building supliers, over her in the UK, B & Q is the place, they sell off damaged blocks for 25% or less of full price, if they don't have any damaged, you can always have an accident with a shopping trolly.
 :D :D :D :D
