Author Topic: Cutting timing belt gears with a slitting saw (and cnc)  (Read 18141 times)
Offline stefang
« on: November 01, 2011, 04:11:02 PM »
Hi folks, got something new (at least I have not seen it so far): Cutting a timing belt gear only with a slitting saw.
Main setback is, that it only works for trapezoid gear tooths, and requires cnc with a rotary axis.
Make one cut in the centre, rotate, cut the lower flank of the tooth, rotate, cut the upper flank of the tooth, rotate to next tooth...sounds pretty simple :D
Gcode was done by hand, suitable for Emc2.
Video of the process:
Looks like a nice timing belt gear, except that I had litte problems on the lower half of it  :palm:
But issn't anything close to a fit  :lol:
Problem was, that I messed up the angle between the teeth...
Another attemt after correcting the Gcode:
Now it's a nice fit:
It's not perfect as it misses the radiuses on top and bottom of the gear tooths (so it might shredd the belt after some time), but for lowtech-lowspeed-applications it should be adequate.
Stefan
Re: Cutting timing belt gears with a slitting saw (and cnc)
« Reply #1 on: November 01, 2011, 07:01:23 PM »
Nice. Sounds like you might need a round over tool to get that top part of the tooth rounded. Up oneside of the tooth and then down the other.   :dremel:
« Reply #2 on: November 01, 2011, 08:18:35 PM »
Or get a copy of Gearotic.
www.gearotic.com
then you cam cut gears and timing belts with off the shelf end mills.
John S.
Offline geoff
« Reply #3 on: November 01, 2011, 09:20:11 PM »
This pulley gear designer will also do timing pulleys using a 4th axis:
http://svstuff.com/gears/
Only $12; haven't used it myself but it looks the part.
From my understanding, gearotic only does 2.5d cutting for timing pulleys which doesn't strike me as optimal.
« Reply #4 on: November 01, 2011, 10:11:33 PM »
An excellent idea for using CNC to get this done.
I wish that I would have had a CNC 4th axis while I made a bunch of timing gears.  Instead, I had made up a spreadsheet with each angle that I needed to stop at, and painstakingly dialed in each one.  It isn't hard to grind a suitable form tool to single point cut.  I don't remember how many teeth my 5" diameter gear had, but I know my back was sore after bending over the machine for so long!
Results were great though.  A bit of fine sandpaper (with aluminum) cleans up the sharp edges quite nicely.
All rammed up and ready for casting, using an open mold:
http://i296.photobucket.com/albums/mm185/sparky961/Metalworking/Setups/IM001063.jpgCutting timing belt gears with a slitting saw (and cnc)
After cleaning up the castings on the lathe:
http://i296.photobucket.com/albums/mm185/sparky961/Metalworking/Setups/IM001067.jpgCutting timing belt gears with a slitting saw (and cnc)
Single point cutting of teeth using rotary table:
http://i296.photobucket.com/albums/mm185/sparky961/Metalworking/Setups/IM001066.jpgCutting timing belt gears with a slitting saw (and cnc)
http://i296.photobucket.com/albums/mm185/sparky961/Metalworking/Setups/IM001068.jpgCutting timing belt gears with a slitting saw (and cnc)
A few operations (and many hours) later, one finished custom pulley:
http://i296.photobucket.com/albums/mm185/sparky961/IM001074.jpgCutting timing belt gears with a slitting saw (and cnc)
