Author Topic: Newbie with Warco lathe question  (Read 10536 times)
Offline mechanoid
« on: August 18, 2011, 06:47:04 AM »
Hello, first post, just getting back into machining and starting to build my shop up. I have a bit of an issue, can anyone advise what is the current Warco WM280 lathe and where it is on there site.
I know this sounds like an obvious question, but any response appreciated.
Re: Newbie with Warco lathe question
« Reply #1 on: August 18, 2011, 07:15:34 AM »
Offline Jasonb
« Reply #2 on: August 18, 2011, 08:03:48 AM »
If you can afford teh extra I'd suggest you go for the variable speed one and preferably power cross feed.
http://www.warco.co.uk/WM-280V-F-Variable-Speed-Lathe-5995194573.aspx
Offline mechanoid
« Reply #3 on: August 18, 2011, 10:47:57 AM »
Isn't the first WM280 highlighted by Pete variable?
Offline Jasonb
« Reply #4 on: August 18, 2011, 11:17:58 AM »
I saw the "WM-280B" in the link and that used to be the belt drive version but the actual link takes you to the variable speed lathe without power cross feed. Seems they no longer do the belt drive one. So yes the variable is better but for teh extra £100 ore so the power cross feed is very handy, I would not be without it now having had the lathe for about 3 years.
J
Offline Deko
« Reply #5 on: August 18, 2011, 05:34:39 PM »
You could also check on the Chester UK   DB10VS, same lathe different colour, and about £100 less cost.   I have no connection to Chester UK, just a satisfied customer
              Cheers  Derek
Offline Jasonb
« Reply #6 on: August 19, 2011, 02:29:53 AM »
The DB10VS (250mm swing, etc)is not the same but the DB11VS (280mm swing) is similar.
Offline Deko
« Reply #7 on: August 19, 2011, 02:21:52 PM »
Whoops!!!   Jason is right of course, i confess i did not read the spec., just went on looks at a quick glance.
