Author Topic: Edge finder  (Read 8380 times)
Offline steam oil
Edge finder
« on: August 17, 2011, 07:59:13 AM »
I have a starrett double end edge finder, I use the parallel end on the mill with no problem but how or for what is the pointed end used for?
Brian
Offline Anzaniste
Re: Edge finder
« Reply #1 on: August 17, 2011, 08:59:46 AM »
I use the pointy end for picking up a centre pop. Lower the point gently into the pop mark and let the weight of the spindle hold it in place. Then adjust the X and the Y feeds until there is no displacement on the main shank of the centre finder.. It's remarkable how can feel a very small displacement with your finger nail. You could use it to palce a small hole under the centre of the spindle in a similar manner.
Offline picclock
Re: Edge finder
« Reply #2 on: August 17, 2011, 05:26:01 PM »
Hi Brian
It seems quite easy to feel displacements of even 1 thou with the pointed end. I located the point on mine in a centre drill mark, and by rotating the ER32 collet could feel the runout change position with the spindle, so its fairly accurate.
Best Regards
picclock
Offline Anzaniste
Re: Edge finder
« Reply #3 on: August 18, 2011, 02:18:49 AM »
Picclock, sounds like you got your ER32 chuck from the same place as me!!!!!   :doh:
Offline steam oil
Re: Edge finder
« Reply #4 on: August 18, 2011, 07:47:47 AM »
Thanks for the replies, obvious now a case of brain cells getting older. :doh:
Brian
