Author Topic: Pipe tap  (Read 10779 times)
Offline J. Tranter
Pipe tap
« on: August 08, 2011, 03:28:08 PM »
I need to tap a hole in some aluminum with a pipe tap.. How far in do you need to run the tap to have good threads?
Thank you for the help
John T.
Re: Pipe tap
« Reply #1 on: August 08, 2011, 03:51:03 PM »
Is this a straight or taper thread? Is it just mechanical or to seal?
Offline J. Tranter
Re: Pipe tap
« Reply #2 on: August 08, 2011, 07:57:40 PM »
It's a tapered 1/2 x 14 pipe tap. It needs to seal.
Re: Pipe tap
« Reply #3 on: August 08, 2011, 08:14:27 PM »
Offline J. Tranter
Re: Pipe tap
« Reply #4 on: August 08, 2011, 08:38:34 PM »
Thank you for the help.
