Author Topic: Nemett 15cc 4 stroke engine  (Read 98628 times)
Re: Nemett 15cc 4 stroke engine
« Reply #50 on: August 30, 2011, 10:13:42 AM »
Real nice neat work Roy
 :thumbup: :thumbup: :thumbup:
 :clap: :clap: :clap:
 I've bin quetly following along.
« Reply #51 on: August 30, 2011, 12:01:52 PM »
COR!!  :bugeye:
I really like that little carb......  :thumbup:
Offline wheeltapper
  • Spixworth Norfolk
« Reply #52 on: August 30, 2011, 12:59:57 PM »
Thanks, I just hope the darn thing works. :doh:
Roy.
Offline wheeltapper
  • Spixworth Norfolk
« Reply #53 on: September 03, 2011, 10:42:05 AM »
just a couple of bits.
now I've got a rotary table I can do the con rod.
I've also made and fitted the piston rings.
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/conrodwithbearingpistonwithrings.jpgNemett 15cc 4 stroke engine
cheers
Roy
« Reply #54 on: September 06, 2011, 01:11:25 PM »
Hi Roy  :bow: :bow: :bow:
you have made a cracking job of making the  carb  :bow: :bow: :bow:   and some dam fine machining on the rest of the engine parts too  :thumbup:,,, i will be watching this build as i fancy building this engine one day .
« Reply #55 on: September 06, 2011, 01:29:39 PM »
Roy,
Very nice work, - smashing carb :thumbup: :thumbup: :thumbup: :clap: :clap: :clap:
Offline wheeltapper
  • Spixworth Norfolk
« Reply #56 on: September 06, 2011, 01:31:27 PM »
thanks guys.
Roy
« Reply #57 on: September 06, 2011, 02:45:33 PM »
Wow... Looking good!
« Reply #58 on: September 06, 2011, 06:05:07 PM »
Roy
That piston & rod look great  :thumbup: :thumbup: :thumbup:
I like the needle roller in the big end  :bugeye: :bugeye: :bugeye:
Some very nice machining there
« Reply #59 on: September 07, 2011, 01:47:44 PM »
I dont usually embarrass myself in public but I had to take a pic of this.
poor mans DRO.
can I nominate it for bodge of the year? :lol:
I had to move the mill table an exact amount for the hole centres of the con rod for this engine.
steel bar clamped to the lathe tray, square clamped to that, digital caliper clamped to the mill vise and the other bit of the caliper clamped to the square.
piece of wood to take out the spring. :bugeye:
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/poormansdro.jpgNemett 15cc 4 stroke engine
am I mad or what?
Roy
That can be no embarrassment, but rather the cobbled together accuracy test of the decade, and should be enshrined with a framed picture on the wall of your shop.  I'll second that call for "bodge of the year!! :nrocks: :bow: :mmr:  :beer: Cheers, mad jack
« Last Edit: September 08, 2011, 02:23:55 AM by Stilldrillin »
Offline wheeltapper
  • Spixworth Norfolk
« Reply #60 on: September 17, 2011, 12:06:59 PM »
another step forward.
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/camboxbits.jpgNemett 15cc 4 stroke engine
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/cambox.jpgNemett 15cc 4 stroke engine
cambox.
more to follow soooooon :D
Roy
Offline wheeltapper
  • Spixworth Norfolk
« Reply #61 on: September 27, 2011, 08:05:20 AM »
more progress, the cylinder head is finished ( apart from pressing in the valve guides when I get some phosfor bronze to make em.)
heres the top
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/completehead.jpgNemett 15cc 4 stroke engine
and the bottom
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/completehead2.jpgNemett 15cc 4 stroke engine
and all dressed up
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/headalldressedup.jpgNemett 15cc 4 stroke engine
I think I will attempt the cams next.
thanks for looking.
Roy
« Reply #62 on: September 27, 2011, 08:13:37 AM »
They're all looking really good Roy!  :clap: :clap:
Keep 'em coming......  :thumbup:
« Reply #63 on: September 27, 2011, 01:13:22 PM »
Roy,
Some very nice maching  :thumbup: :clap:
Looking great :thumbup: :clap:
« Reply #64 on: September 27, 2011, 02:00:26 PM »
Roy,
That is looking sharp!
Offline wheeltapper
  • Spixworth Norfolk
« Reply #65 on: September 28, 2011, 11:50:48 AM »
a bit more done.
cams cut, fitted to shaft and installed in cambox.
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/camboxwithcamshaft.jpgNemett 15cc 4 stroke engine
cheers
Roy
« Reply #66 on: September 29, 2011, 10:31:51 PM »
Wow, really nice work on the head  & cambox.  :thumbup: It is a really nice design this engine.
Offline wheeltapper
  • Spixworth Norfolk
« Reply #67 on: September 30, 2011, 08:33:11 AM »
thanks for the nice words guys, this is the first major thing I've built and the encouragement is appreciated.
and now, the beast temporarily assembled.
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/thebeastassembled2.jpgNemett 15cc 4 stroke engine
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/thebeastassembled.jpgNemett 15cc 4 stroke engine
not far now.
Roy
« Reply #68 on: September 30, 2011, 08:37:31 AM »
Looking purposeful Roy!  :thumbup:
« Reply #69 on: September 30, 2011, 08:38:26 AM »
 :drool: NICE ONE Roy  :clap: :clap: :clap: :clap: :clap: :clap:
Thats a mighty fine looking engine ,,,,,, well done  :thumbup:  I will be looking forward top seeing the video of her running  :)
« Reply #70 on: September 30, 2011, 12:04:36 PM »
It looks like you're really getting close now, we ought to be treated to some sound and fury out of the little beast fairly soon I expect.  Very nicely done, fine craftsmanship all the way. :bugeye: :jaw: :beer:  Cheers, mad jack
Offline wheeltapper
  • Spixworth Norfolk
« Reply #71 on: October 04, 2011, 03:58:59 PM »
Hi all
I had a bit of a shock earlier, I made the timing disc to set the timing and discovered to my horror that the cams  were assembed wrongly on the shaft. :doh: :doh:
I managed to break the loktite grip with a small blowtorch so now I can do it again PROPERLY :bang: :bang:
Oh well, something had to go wrong sooner or later.
Roy
« Last Edit: October 04, 2011, 04:59:48 PM by wheeltapper »
« Reply #72 on: October 06, 2011, 11:36:38 AM »
It is a long honored tradition in the far east, China in particular, but other places as well, to deliberately insert an error in a work, whether art, building, dish, everything which demands skill, just to demonstrate no intent of challenging the perfection of creation.  It is said that failing to do so will invoke an unintended error, which will interfere with the intended job one is doing, so maybe you need to put a flaw in it, so you won't get something else wrong.  I think some of these old traditional thoughts which have echoes in our own societies are of real value in putting our work and lives into perspective in the world at large.  Lots of fine looking parts, and getting awfully close to a finish line I hope.  Very nice work, and it should be a great runner. :jaw: :beer:  Looking forward to video, cheers, mad jack
Offline SCOOTER
« Reply #73 on: October 12, 2011, 09:07:02 PM »
Nice looking engine and some realy nice machining i am looking forward to seeing her run. :clap:
Offline wheeltapper
  • Spixworth Norfolk
« Reply #74 on: October 14, 2011, 12:37:38 PM »
THE BEAST LIVES :D :) :D :)
It only works.
here are some pics of it ready to run,
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/nemett%2015cc%20engine%20running/DSCF0753.jpgNemett 15cc 4 stroke engine
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/nemett%2015cc%20engine%20running/DSCF0752.jpgNemett 15cc 4 stroke engine
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/nemett%2015cc%20engine%20running/DSCF0751.jpgNemett 15cc 4 stroke engine
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/nemett%2015cc%20engine%20running/DSCF0750.jpgNemett 15cc 4 stroke engine
and a couple of videos,
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/nemett%2015cc%20engine%20running/bestrun2.jpgNemett 15cc 4 stroke engine
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/nemett%2015cc%20engine%20running/bestrun.jpgNemett 15cc 4 stroke engine
and some pics after stripping, cleaning and shining up a bit,
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/PA140003.jpgNemett 15cc 4 stroke engine
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/PA140004.jpgNemett 15cc 4 stroke engine
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/PA140005.jpgNemett 15cc 4 stroke engine
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/PA140006.jpgNemett 15cc 4 stroke engine
Am I chuffed or what?
hope you guys enjoy .
cheers
Roy
