Author Topic: condenser tubes  (Read 15372 times)
lordedmond
condenser tubes
« on: July 23, 2011, 07:00:04 AM »
some info please
I am building as a side project a triple expansion engine. I have to seal the condenser tubes into the tube plates which go on the ends of the condenser casting then the end cover go on
the tube plates will not pass through the casting
tubes are 1/4 od and the tube plate is 1/16   inches in both cases
I could soft solder them in but the TP could bend and fail to seal the vacuum ( water is in the tube ) to the casting
Any ideas
Stuart
Offline David Jupp
  • Teesside - UK
Re: condenser tubes
« Reply #1 on: July 23, 2011, 09:38:15 AM »
Is it possible to arrange for one tune plate to 'float' to take up expansion/contraction?
A U tube arrangement with single tube plate wouldn't suffer this problem.
lordedmond
Re: condenser tubes
« Reply #2 on: July 24, 2011, 04:10:22 AM »
thanks for the reply
a floating TP would not seal the vac chamber
I could alter the design to have a u tube arrangement  but getting the bends in may be difficult
Thanks again for the input
Stuart
Offline David Jupp
  • Teesside - UK
Re: condenser tubes
« Reply #3 on: July 24, 2011, 04:16:25 AM »
It would need a suitable seal - no idea if you have room for such.  I've known floating tube plates in heat exchangers sealed to hold significant pressures.
lordedmond
Re: condenser tubes
« Reply #4 on: July 24, 2011, 06:04:44 AM »
the answer is very little
3 1/2 long  2 high and a inch deep
the 3 1/2 is the tube length and it is a two pass system the dwg shows the plates screwed with csk screws to the casting and the end casting bolted through into the casting , but there is no indiction as to the method of sealing.
in full size turbine condensers ( this is a triple expansion engine )  they are expanded into the steel TP and are made of brass tube
these are 1/4 copper in 1/16 TP
as there will be a vacuum out side the tubes and a small water pressure outside  , so the seal would have to stand about 10 psi
Stuart
Offline mgj
Re: condenser tubes
« Reply #5 on: July 27, 2011, 05:24:03 PM »
O ring seals?
or make them a press fit and use Loctite 574 is it.(the orange sealant goop which seals everything.) the Loctite goes into
a shallow groove so its invisible.
lordedmond
Re: condenser tubes
« Reply #6 on: July 28, 2011, 02:49:33 AM »
to tight tube spacing for  O rings
I will look into the goop
Stuart
Offline boatmadman
  • Located in Barrow in Furness, South Cumbria
Re: condenser tubes
« Reply #7 on: July 28, 2011, 05:11:38 PM »
How about make up a suitable taper plug and push into the tube end so the end expands onto the tube plate?
If it works, take it apart and find out why!
Offline mgj
Re: condenser tubes
« Reply #8 on: July 28, 2011, 05:43:16 PM »
Is this a condenser like with a vacuum pump and all?
lordedmond
Re: condenser tubes
« Reply #9 on: July 29, 2011, 02:48:46 AM »
its the condenser for a triple expansion steam engine  it returns the waste steam to water and thus plus a vacuum to improve the efficiency of the final stage
the tube plates are a bit thin at 1.8 mm brass one end is ok as it can be done before assembly a drift could work in the other end though
Stuart
