Author Topic: Quick release vice is this a goodun?  (Read 10894 times)
Offline bry1975
    • http://www.satintime.co.uk
« on: July 13, 2011, 03:19:57 PM »
Chaps,
Is this vice below precise enough for round component drilling on a pedestal drill?
Also do you think the jaw heights are equal?
Tia
Bry
« Last Edit: July 13, 2011, 04:13:08 PM by bry1975 »
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
Re: Quick release vice is this a goodun?
« Reply #1 on: July 13, 2011, 04:44:23 PM »
Hi Bry,
I have a vice that looks identical to that one, it was the 1st vice I used on my mill for a couple of years.
To be honest with you, I found using the vice to be rather frustrating, the reason was that, at least on my vice, the quick release mechanism did not give a full range of clamping ability. On mine the narrow sliding rack that the movable vice jaw would lock into did not have enough movement front-to-back to cover the space between the "notches" in the rack. This meant that I would often have to use a packing slip to enable the vice to be able to tighten up.
Having said that, I used the darn thing for 2-3 years, so it can't have been that bad :lol: But now I have Vertex K4 4" vice which is sooo much better.
I still use the old quick release vice to hold parts for tapping in my tapping stand.
I guess for use in as a drill vice it would be ok, but make sure that the vice will have sufficient range of clamping movement.
Tim
« Reply #2 on: July 13, 2011, 04:50:35 PM »
Strikes me that most drilling jobs would need propping up on parallels so you don't drill though into the base of the vice.
Offline wheeltapper
  • Spixworth Norfolk
« Reply #3 on: July 13, 2011, 04:52:37 PM »
I got one of those with my mill.
It sits at the back of my cupboard now because I cant be bothered with it.
as soon as the slot fills up with swarf the whole lot seizes up and has to be stripped to clean it, add to that the thread on the rod was a load of rubbish and you see why I dont like it.
after having said that I suppose it'd do on  a drill.
not to put you off, of course. :D :) :D
Roy.
Offline bry1975
« Reply #4 on: July 13, 2011, 05:35:50 PM »
Thanks chaps,
No idea what I'm gonna buy now so many vices on ebay some look good some look crap etc etc :lol:
Tempted with an old myford vice that looks quality!?
Offline bry1975
« Reply #5 on: July 14, 2011, 12:25:24 PM »
Decided on the RS comps drill vice below as the quality looks kinda decent it will be here tomorrow so if no good it will be outta the door.  :lol:
